Hey just a quick question: I want to have my whole subnet to be local bandwith but one Ip because that’s the IP where my vpn runs
so under lan networks could i put for example
192.168.0.0/24,~192.168.0.37
~ is there some syntax for [not] ?
There’s no syntax for [not].
Instead, try this. If your LAN is 192.168.0.0/24, configure your DHCP range for 192.168.0.129-192.168.0.254, and put all of your Plex client devices in that range.
That way you can enter 192.168.0.128/25 in LAN Networks to quickly cover them.
Thanks so there is no option to just mark one ip as remote ?
And itwould be alt easier to move the ip i don’t want maybe a option tomove the 192.168.0.37 to another ?
