New Android TV interface is awful
My nVidia Shield got a new interface for Plex last month. It’s nowhere as good as the old interface, for two main reasons. Let me explain why.
Firstly, there is no way to remove items from playlists anymore. Now, in order to remove an item from my playlists after I’ve watched it, I have to do it from my computer.
Secondly, when playing a series, it takes far more button presses to get to the next episode. In the past, after watching an episode, I would just press back on my remote, and then the next episode would automatically be highlighted and I would just click select and it would play. That’s two button clicks: back and select.
Now, when I back out of an episode, it instead highlights to play button for the current episode. So I have to click up twice to go to the episode carousel, then click right, and then click select. That’s five button presses: back, up, up, right, select. Even more button presses if the next episode is in the next season: back, up, up, up, right, select, down, select.
The test with every TV interface is the grandmother/babysitter test. The old interface, I could give to my grandmother, and she could use it. Now, it’s a complete nightmare.
#fire-tv must have gotten the same update, and I have the same two complaints. Just like you, I had to remove an item from a playlist from the computer. And just like you, playing the next episode is a lot more annoying now. This is compounded by the fact that the home screen doesn’t always let you play the next episode directly anymore (I’m not sure why), so I have no choice but to use this inconvenient series page.
I am extremely disappointed with the new Plex app update for android. Navigating TV episodes is borderline unbearable. It takes much longer to scroll and find episodes with its current organization. Additionally, when I finish with one episode and hit back to go to a different season, it takes me back to the Home page/TV Shows folder. If I’m watching an episode and hit “back” on my remote, it should take me to the series/show I’m watching. The new update takes way too long to navigate and is not efficient.
