So I’ve got a question, what if you’ve got a compilation album, but it’s not showing up as a compilation album?
For example, on Musicbrainz, there’s a Creed compilation called ‘With Arms Wide Open: A Retrospective’. I have this in my Plex library, but it’s classing it as an album. Do I need to edit something on Musicbrainz?
Check if it’s “matched” at all in your library.
Take a look at the guid and the parentGuid and the grandparentGuid in the Plex XML info of one of the songs.
Ok, so it’s matched and I checked the XML info, here’s what it says
guid=“plex://track/5d07f2cf403c6402902668fd” parentGuid=“plex://album/5d07c9de403c640290ccb946” grandparentGuid=“plex://artist/5d07bbfd403c6402904a6581”
Apparently there is some inconsistency with when plex picks the primary/secondary type of a release?
I have 3 remix releases, on Musicbrainz they are tagged as single/remix, EP/remix, and album/remix. Only the album/remix one shows up under “Remixes”, the other two are categorized as “Singles and EPs” by plex.
Also, Musicbrainz has Singles and EPs seperatly, can we get that on plex too?
The release group doesn’t have a Primary type set on MusicBrainz, only Secondary type of Compilation, which may be confusing the Plex agent. I suspect the Primary type should be set to Album.
Apologies for the delay getting this done @mrevenflow86 and anybody else who wanted to see it, I had a few other things to get done over the weekend. As promised, here’s a quick guide for editing MusicBrainz with album types
This one really is [ EDIT: Would Be] a present. I have artists like prince, Geroge Benson, Bowie etc with soo many albums and i hate wading through some period where they did a tour and recorded every single concert and you scroll and scroll through 50 identical covered albums to get to the studio album your looking for.
I found this as well with Tidal when within plex…it put all the live and compliations in chrological order rather than grouping them…I’m guessing this issue also will be fixed now, [EDIT…except it hasn’t?. Maybe I’m still waiting for this update?] Why doesnt this work?
So I really want this feature…It IS turned on… but searching for “live” and going to all artists in the search results…none of them have the live albums separated out???
While I do like the album type feature, putting every EP & Single behind a carousel-type feature was maybe not the best choice. There are artists out there that rarely produce albums. AFX for example (AFX - MusicBrainz) now has 1 album for me, and most of his other releases are hidden behind a slider.
Also, the EPs load together with the similar artists slider, which is odd, because my artists page is now mostly empty when it loads…
