New Home Screen Problem
I see as of April 22 they are moving everyone to the new Home screen. I enabled it out of curiosity and I immediately see a problem. There is a category of suggested movies, “Sci-Fi Escapes” which is fine, but it is suggesting ad supported versions of movies from Crackle and Popcornflix instead of the versions that are already on my server. This is pretty shady in my opinion.
Can anyone tell me how to fix this?
Out of interest, do you have add-supported TV switched off in your account?
Where is that option?
If you want to keep the online media sources enabled, you can also “Un-Pin” them from the left-hand side-bar. The hubs from that source won’t show up on the home page, but you can still access the online sources by hitting the “More” button.
I did have settings/online media sources/movies and tv enabled. I have disabled it.
I didn’t mind the suggested category that was inserted into my home page, I just wanted it to use the movies from my collection instead of an ad supported version.
IF it works as intended (across all apps) you can enable stuff, Pin it, then change the sidebar order - to move things on the home screen.
You could move Plex Junk to the bottom - hopefully.
… and, of course, what you do doesn’t do anything for Friends and Family.
…they’ll need to wrangle the beast themselves.
New feature, crashed my server…
Happens 1 in 2 or 3 times with Plex. I’m kinda used to it but frankly I can do without botched releases.
Especially when the new features have absolutely nothing for me. I’ve been waiting for landscape posters for 5 years. That can wait apparently.
1.22.1 crashed for me as well, but 1.22.2 works.
