Just got the Plex Beta installed on my new iPad Pro 11".
Oddly, the app is saying my server is offline, even though I can access it from everything else (other iPad, iPhone or web)
Any troubleshooting I can do, or logs I can provide?
I would use the “email device logs” method here to get logs. Do you have any servers shared with you? if so can you see those?
I had this issue, but logging out of the app on my iPad, deleting the app, reinstalling the app and then logging back in seemed to fix things for me.
Excellent, I grabbed my logs.
Additionally, I cannot see content from other servers as well.
@BigWheel I can try deleting and reinstalling like @Dustjunky suggested but want to see if there was more info that would be helpful for debugging.
@anthonysnyder if you can provide logs as well that would be appreciated. There were a bunch of authentication errors in the logs @Dustjunky provided it may help to know if they are the same type of errors. i am wondering if the issue is only with updating from a previous version and not a clean/fresh install. One of our devs with the new iPad Pro could not reproduce it though.
logs removed by mod
Logs!
FWIW, this was a brand new iPad Pro that was restored from a backup.
interesting. @Dustjunky was yours also a restore?
Yep, I restored from a backup also
Chiming in as I also performed a backup restore onto the new iPad Pro with the same issues as the others reporting in.
Uninstalling the app and reinstalling it fixed the issue.
@BigWheel Anything else you want me to get off this device, or should i try the delete and reinstall
No nothing else. I would try to just sign out then back in first. Might not have to completely uninstall
¯_(ツ)_/¯
Logging out and back in resolved the issue without having to delete. Thanks for the help!
