Hi all. So I am NOT a networking guy…at all. I just recently got a Synology DiskStation DS1621xs+ and setup plex on it. It’s working fine over my home network. But no matter what I try to do I can’t access it outside of my home network. It just shows “offline.” My plex settings seem fine…it says it’s being shared. I’ve searched the forums and I just can’t understand anything I’m reading to try and trouble shoot it lol. Anyone willing to help walk me through figuring out the issue?
The Nas is connected to a 10GBe switch. My router is also connected to the switch. In the synology settings I have read/write access for plex set to allow for everyone. So Im not sure where I’m going wrong. TIA
Basics would be great. Even those are a little over my head lol. But let me see if I can answer:
(1) I believe my devices are all on the 192.168.x.x number system
(2) It looks like the Syno Firewall is disabled. Under control panel - Firewall - Enable firewall…its not checked.
(3) The Wan IP of the Router is set to “automatic ip”
Im sorry for my ignorance. I work from home and this NAS was sent to me by my employer to back all of my work up on. So I’m not used to having to do this level of networking.
Yeah Im capable of getting in to the different menus etc. And have a general knowledge of basic networking stuff. So I should be able to find stuff to check. I set up the NAS following a tutorial on youtube. I just need to make sure that I don’t mess up my connections to my two desktops. They are both connected via 10Gbe. I need the speed between the two in order to transfer my large video files etc back and forth all day.
I wanted to confirm this wasn’t a simple case of Double NAT (router behind another router). It doesn’t sound like it but now we can go further.
log into the ASUS
On the WAN page. Check the address.
Confirm it’s reporting a true public IP address and not in the 100.64.x.x-100.127.x.x range (CGNAT) or 192.168.x.x, or 10.x.x.x, or 172.16.x.x-172.31.x.x (RFC-1918)
Presuming it’s a proper IP address, we can setup Port Forwarding manually.
You control the Running/Stopped status in Package Center .
Change from Running → STOP
Let it sit idle a minute
Click “Run” and it will start Plex.
Logging in and out of the Plex/web UI is just that… sign in/out.
I need to see what the server is doing when it starts. The UI is known to work so we don’t need to diagnose it.
I found where your server is reachable (Remote Access is active)
Oct 29, 2021 10:26:08.638 [0x7f9867d11700] DEBUG - PubSub: Got notified of reachability for async identifier b1b2f2db-7cbd-434d-9e66-26f6035ef1a7: 1 for 75.170.220.203:20293 (responded in 0 seconds)
1 = Remote Access ON
0 = Remote Access OFF / blocked.
This tells me the apps are looking for the wrong Hostname / Identifier (which can happen).
When the apps get out of sync, I just reload them and pin them again (it’s the easiest way to me)
