I had opened another issue about this a few months back, and provided logs and such, but there wasn’t a solution and I had gone back to the legacy agent (that topic has since been closed due to inactivity).
I am now trying the new plex agent again and still the same issues.
I just added a new movie called Why Me!. There is also an nfo in there that just contains the imdb and tmdb links and nothing else.
After a library scan, the movie appears as unmatched. When I click on Match in the context menu, it does show me multiple options, with the correct option as the first listing, however, if I select Auto Match and then Plex Movie, I get an error message: No matches were found using this agent.
The Plex Media Scanner Matcher log shows that the library scan indeed identified the movie by pulling the imdb link from the nfo, but it still did not match it.
# cat Plex\ Media\ Scanner\ Matcher.log
Jun 17, 2021 13:37:36.804 [0x1553e8012b38] INFO - Plex Media Scanner v1.23.2.4656-85f0adf5b - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 - GMT -04:00
Jun 17, 2021 13:37:36.804 [0x1553e8012b38] INFO - Linux version: 5.10.28-Unraid, language: en-US
Jun 17, 2021 13:37:36.804 [0x1553e8012b38] INFO - Processor Intel(R) Pentium(R) CPU G4600 @ 3.60GHz
Jun 17, 2021 13:37:36.804 [0x1553e8012b38] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --match --type 1 --log-file-suffix Matcher --item 219267
Jun 17, 2021 13:37:36.805 [0x1553ea816808] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Jun 17, 2021 13:37:36.899 [0x1553ea816808] DEBUG - Matcher: found 1 auxiliary files in "/tower/Movies/Why Me! (1990)" (single media: yes)
Jun 17, 2021 13:37:36.899 [0x1553ea816808] DEBUG - Scanner [Plex Movie]: found local nfo file "/tower/Movies/Why Me! (1990)/Why Me! (1990) Bluray-720p (Why.Me.1990.720p.BluRay.FLAC.x264-HANDJOB).nfo"
Jun 17, 2021 13:37:36.900 [0x1553ea816808] DEBUG - Scanner [Plex Movie]: extracted IMDB id 'tt0100931' from "/tower/Movies/Why Me! (1990)/Why Me! (1990) Bluray-720p (Why.Me.1990.720p.BluRay.FLAC.x264-HANDJOB).nfo"
Jun 17, 2021 13:37:36.900 [0x1553ea816808] DEBUG - Matcher: no sidecar subtitle files found for "/tower/Movies/Why Me! (1990)/Why Me! (1990) Bluray-720p (Why.Me.1990.720p.BluRay.FLAC.x264-HANDJOB).mkv"
Jun 17, 2021 13:37:36.901 [0x1553ea816808] DEBUG - Matcher: no valid subtitles found, removing any existing media bundle file
