New PMS with same hostname as old one - no migration
Server Version#: # rpm -qa | grep plexmediaserver
plexmediaserver-1.19.4.2865-4fa317f77.x86_64
Player Version#: local web server
I had a functional PMS on an old server in my cabinet. Worked just fine. I decided to scale back and deployed Plex on a new SFF system. I decided to “start from scratch” because the original deployment was a bit of a learning experience.
I used the same hostname for the new machine. Everything installed and started cleanly.
Browsing to http://plex.int.jduncan.io:32400/web works fine. I’m able to log in. But I can’t see any server settings. There was no setup wizard.
What I’ve attempted:
  • removing the Application\ Support directory and restarting the service
  • removing the RPM and re-installing
I’m wrapped around the axel of how to point this new server at my existing account. All help appreciated.
OS: CentOS 7
Plex version: above, installed via RPM
Service status:
systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server
   Loaded: loaded (/usr/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: disabled)
   Active: active (running) since Sun 2020-05-31 16:53:41 EDT; 16min ago
  Process: 20009 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS)
 Main PID: 20014 (Plex Media Serv)
   CGroup: /system.slice/plexmediaserver.service
           ├─20014 /usr/lib/plexmediaserver/Plex Media Server
           ├─20035 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py -...
           ├─20073 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.19.4.2865-4fa...
           └─20105 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap...
May 31 16:53:41 plex.int.jduncan.io systemd[1]: Starting Plex Media Server...
May 31 16:53:41 plex.int.jduncan.io systemd[1]: Started Plex Media Server.
Log snippet:
May 31, 2020 16:58:17.548 [0x7f1e237fe700] DEBUG - Content-Length of /usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/WebClient.bundle/Contents/Resources/common/img/backgrounds/noise.8b05ce45d0df59343e206bc9ae78d85d.png is 54413 (of total: 54413).
May 31, 2020 16:58:17.548 [0x7f1e759ef700] DEBUG - Completed: [192.168.1.176:60661] 200 GET /web/common/img/backgrounds/noise.8b05ce45d0df59343e206bc9ae78d85d.png (4 live) GZIP 0ms 54413 bytes (pipelined: 2)
May 31, 2020 16:58:17.733 [0x7f1e761f0700] DEBUG - Request: [192.168.1.176:60660 (WAN)] GET /media/providers (4 live) GZIP
May 31, 2020 16:58:17.734 [0x7f1e761f0700] DEBUG - Completed: [192.168.1.176:60660] 401 GET /media/providers (4 live) GZIP 0ms 357 bytes
May 31, 2020 16:58:17.734 [0x7f1e759ef700] DEBUG - Request: [192.168.1.176:60661 (WAN)] GET / (3 live) GZIP
May 31, 2020 16:58:17.734 [0x7f1e759ef700] DEBUG - Completed: [192.168.1.176:60661] 401 GET / (3 live) GZIP 0ms 435 bytes
May 31, 2020 16:58:17.772 [0x7f1e237fe700] DEBUG - Request: [192.168.1.176:60662 (WAN)] GET /identity (2 live) GZIP
May 31, 2020 16:58:17.773 [0x7f1e761f0700] DEBUG - Completed: [192.168.1.176:60662] 200 GET /identity (2 live) GZIP 0ms 480 bytes (pipelined: 3)
May 31, 2020 16:58:19.644 [0x7f1e237fe700] DEBUG - Request: [192.168.1.176:60662 (WAN)] GET /web/common/img/backgrounds/preset-light2.ead08af5122abea1ab8f7d601fd93d6a.png (2 live) GZIP
May 31, 2020 16:58:19.645 [0x7f1e237fe700] DEBUG - Final path: "/usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/WebClient.bundle/Contents/Resources/common/img/backgrounds/preset-light2.ead08af5122abea1ab8f7d601fd93d6a.png"
May 31, 2020 16:58:19.645 [0x7f1e237fe700] DEBUG - Content-Length of /usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/WebClient.bundle/Contents/Resources/common/img/backgrounds/preset-light2.ead08af5122abea1ab8f7d601fd93d6a.png is 125754 (of total: 125754).
May 31, 2020 16:58:19.645 [0x7f1e759ef700] DEBUG - Completed: [192.168.1.176:60662] 200 GET /web/common/img/backgrounds/preset-light2.ead08af5122abea1ab8f7d601fd93d6a.png (2 live) GZIP 1ms 125754 bytes (pipelined: 4)
May 31, 2020 16:58:45.247 [0x7f1e237fe700] DEBUG - Request: [192.168.1.176:60689 (WAN)] GET /web/desktop/common/img/pp-ticket.de3ffb4d2327ee50e4290f8467a1796b.svg (2 live) GZIP
May 31, 2020 16:58:45.247 [0x7f1e237fe700] DEBUG - Final path: "/usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/WebClient.bundle/Contents/Resources/desktop/common/img/pp-ticket.de3ffb4d2327ee50e4290f8467a1796b.svg"
May 31, 2020 16:58:45.248 [0x7f1e237fe700] DEBUG - Content-Length of /usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/WebClient.bundle/Contents/Resources/desktop/common/img/pp-ticket.de3ffb4d2327ee50e4290f8467a1796b.svg is 5092 (of total: 5092).
May 31, 2020 16:58:45.248 [0x7f1e759ef700] DEBUG - Completed: [192.168.1.176:60689] 200 GET /web/desktop/common/img/pp-ticket.de3ffb4d2327ee50e4290f8467a1796b.svg (2 live) GZIP 0ms 5092 bytes (pipelined: 1)
May 31, 2020 16:58:45.290 [0x7f1e237fe700] DEBUG - Request: [192.168.1.176:60689 (WAN)] GET /web/common/img/backgrounds/preset-dark2.6d2c8336496f761f38de8558a2b9709b.png (2 live) GZIP
May 31, 2020 16:58:45.290 [0x7f1e237fe700] DEBUG - Final path: "/usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/WebClient.bundle/Contents/Resources/common/img/backgrounds/preset-dark2.6d2c8336496f761f38de8558a2b9709b.png"
May 31, 2020 16:58:45.290 [0x7f1e237fe700] DEBUG - Content-Length of /usr/lib/plexmediaserver/Resources/Plug-ins-4fa317f77/WebClient.bundle/Contents/Resources/common/img/backgrounds/preset-dark2.6d2c8336496f761f38de8558a2b9709b.png is 113817 (of total: 113817).
May 31, 2020 16:58:45.298 [0x7f1e759ef700] DEBUG - Completed: [192.168.1.176:60689] 200 GET /web/common/img/backgrounds/preset-dark2.6d2c8336496f761f38de8558a2b9709b.png (2 live) GZIP 8ms 113817 bytes (pipelined: 2)
May 31, 2020 16:59:17.783 [0x7f1e759ef700] DEBUG - Request: [192.168.1.176:60738 (WAN)] GET /media/providers (3 live) GZIP
May 31, 2020 16:59:17.784 [0x7f1e759ef700] DEBUG - Completed: [192.168.1.176:60738] 401 GET /media/providers (3 live) GZIP 0ms 357 bytes
May 31, 2020 16:59:17.790 [0x7f1e761f0700] DEBUG - Request: [192.168.1.176:60739 (WAN)] GET / (2 live) GZIP
May 31, 2020 16:59:17.791 [0x7f1e761f0700] DEBUG - Completed: [192.168.1.176:60739] 401 GET / (2 live) GZIP 0ms 435 bytes
May 31, 2020 16:59:17.825 [0x7f1e237fe700] DEBUG - Request: [192.168.1.176:60742 (WAN)] GET /identity (2 live) GZIP
May 31, 2020 16:59:17.825 [0x7f1e761f0700] DEBUG - Completed: [192.168.1.176:60742] 200 GET /identity (2 live) GZIP 0ms 480 bytes (pipelined: 1)
May 31, 2020 17:00:12.023 [0x7f1e23fff700] DEBUG - Statistics: Flushing 2 expired bandwidth entries, 0 expired media entries.
Figured this out. My wifi and home lab networks are on different subnets. I used the SSH-forwarding approach initially but had forgotten.
All working again now.
/close
