New Tizen Preview app require force quit and start always
I’ve been seeing the same issue and I would hazard a guess that all of these cases are being launched from the app sitting on the launcher bar, rather than the apps screen.
Certain Tizen devices try to be smart and prelaunch the apps on that bar, hidden in the background. It means a faster start up because they’re waiting to go. Unfortunately if the prelaunch occurs before the network is ready (as Volts pointed out) then the app can get stuck and when you “launch” it for the first time all you’re doing is pulling the broken app to the foreground. That’s why an exit and relaunch fixes it, because it’s now launching with a working internet connection.
Until the app can hold out for longer, disable prelaunch, or attempt recovery then the temporary solution might be to remove Plex from the bar and access it via Apps instead.
@mathewilson Exactly that is the problem with my KS7090!
@sLumpy Any update as issue still happening.
Thanks for this explanation. How to explain with same TV when used the OLD app, and launch from smart TV bar issue is not present.
I was using the OLD app for years and this issue not happened.
I suspect new changes in the app causing this issue.
@sLumpy Can you add internet check while loading the app and then load? If you look at other apps like Netflix and YouTube they display error message while loading the app if internet is not available.
The TV already checks if the app is on network or not. It prevents you from launching the app if so (at least it does for me, unless it has changed recently). In the cases where you somehow get into the app without and internet connection, it should fall back gracefully to offline usage. I suspect something is up there, but we’re still investigating.
I’m seeing this issue on both my Samsung TVs (KS8000 series and KU6000 series, which both run Tizen 2.4).
Do you have all logs that you need @sLumpy, or can I help with anything?
I quit the Tizen Preview and stopped to care. But please don’t force us to use the new app with this error.
@sLumpy please provide an update on this as it’s open for months now. What is PLEX position on this bug as if unable to fix please let me know as planning to seek a refund on my subscription.
@AliveKiller Now that’s going too far. This is only a preview. Just opt-out of the preview as I did and it is fixed. Let’s hope that PLEX could reproduce this somehow.
Oh I see. Will do that. I thought it’s mandatory to use this app.
@sLumpy I can see new app got more logging options. Do you need any extra logs to fix this?
You guys done an amazing job with PLEX over the years and why this issue unable to resolve?
I’ve added a change in the next release that hopefully will address this. Once the next release is out, let me know if it fixes it or not. I can’t reproduce the problem so I can’t test if it’ll be fixed or not.
Thanks. Next change in the server or client? In any case: which version number?
@sLumpy as I said before this is happening with Samsung Tizen 2016 TV models and specific to the models in this thread. Are you testing in these models?
If not I am happy to be at your assistant. I can even install a test build or open a FW to my TV IP and let you do your magic or follow specific steps.
It’s not an excuse to say I can’t reproduce therefore I can’t fix as you can’t simply replicate all variables.
Let me know if any help needed as happy to help.
It’s not an excuse, it’s a fact that all the Samsung devices differ regardless of TV models. We’ve had many bugs where they are reproducible only on certain devices even though it’s the same Tizen version, same series, or even the same model number. If I can’t reproduce it, then it makes it far more difficult to track down and debug. That doesn’t mean we won’t fix it, it means that it’s a bit of a shot in the dark when attempting to put in a fix.
We can’t send out one-off builds via USB anymore because of Samsung’s T&C’s. We have a way to load test builds though, I can ping you once the changes have landed but I’d need your Plex username (which you can DM to me).
Sent the details. Let me know if you need more info…
Another Plex user here experiencing the same load hang. Plex version 5.1.0.
Unfortunately I finally gave up on this… even I send the logs from test build and replicated the issue the bug was not fixed…
I have bought a new NVEDIA Shield and stop using the PLEX Samsung App… hope this issue will be fixed for others users.
I’ve been having this issue for a while now too.
Is the consensus to give up and live with it? That’s frustrating…
Really excited for the next release, and happy to do any testing that could help!
