New UI Help?
I just got home and noticed the UI had changed which means the app was updated on my Samsung tv. How do I access the tabs from the server (my PC)?
Not sure what you mean here, but if your Sammy TV is 2016+ then in the left menu there’s a more option
It’s a 2018 model. The pinned channels I had aren’t even there and I don’t see a more option. It looks similar to this
Did you change your Plex password?
And after that, reclaimed your server?
See: Important notice of a potential data breach 24th of August 2022
I’ll try when I get home.
How do I reclaim my server
Depends on your server OS, but instructions are on the post I linked towards
All I had to do was update the software on my server and everything looks fine now.
