News shows not associate
Server Version#: 1.26.0.5715
Ubuntu 20.04
Docker
When new show is detected, is not associate. I need to associate manually, And when I do it manually, no problem, first match is good.
I tried with others agents, but same problem.
Apr 28, 2022 17:07:43.091 [0x7ffa2aae3b38] WARN - Held transaction for too long (/data/jenkins/server/3529576666/Library/MetadataCollection.cpp:479): 0.200000 seconds
Apr 28, 2022 17:07:43.271 [0x7ffa2aae3b38] WARN - Held transaction for too long (/data/jenkins/server/3529576666/Library/MetadataCollection.cpp:479): 0.170000 seconds
Apr 28, 2022 17:07:46.159 [0x7ffa2aa36b38] WARN - Scanner [Plex TV Series]: unable to find cloud match for item file '/data/video/series/Halo/Saison 01/S01E01 - Contact.mkv'
Apr 28, 2022 17:07:48.693 [0x7ffa2aa36b38] WARN - Held transaction for too long (/data/jenkins/server/3529576666/Library/MetadataItem.cpp:3910): 0.240000 seconds
What I can do?
Plex DocsYour MediaNaming & Organizing Your TV Show Files
Try following the Plex naming convention a little closer.
  • Add the year to the show. There are multiple TV shows with “Halo” in the name. Adding the year helps Plex pick the correct show.
  • The TVDB/TMDB ID is optional, but tells Plex which exact show to match.
  • Use “Season” vs “Saison”
/series <-- folder added to TV show library
.../Halo (2022) {tvdb-366524}  <-- Show_Name (year); ID optional, helps matching
....../Season 01 <-- "Season" in English; two digits for season number
........./Halo (2022) - s01e01 - Contact.mkv <-- Show_Name (year) - sXXeYY - episode_name.ext
Thanks, I’ll try.
All goods with your advice @FordGuy61 ! Thanks!
Solved
:partying_face:
