Next episode in series not autoplaying, no countdown
I recently got an android tv box from directv stream and just have 2 issues with it. 95% of the time it will not autoplay the next show in a series. The screen will just go blank and then you need to use the remote to skip to the next episode and then when doing that (or sometimes just in the middle of a show) it will go black and you need to skip ahead about 30 seconds and then it will start playing again (I usually skip back the 30 seconds so I don’t miss anything, so I know its playable). I don’t have this issue on anything other than this box. I suspect it to just be an issue with the app version but is there anything I can try?
And to clarify it will very rarely do the 10 second count down and move on to the next episode on its own. Maybe every 5/100 episodes.
Stream Box Info:
Model: C71KW-400,
android 10,
security patch 7/5/21
Plex App v8.22.0.27544(bdaff3f3)
Plex Media Server Logs_2021-09-12_20-12-38.zip (4.6 MB)
We’ve been waiting a long time for this to be fixed :frowning:
