NextPVR Channel - Please check file exists and drive is mounted
RasPlex version: 0.4.1
NextPVR version: 3.3.8
PMS Version: 0.9.11.4.739-a4e710f
PMS Environment: Windows 8
Codecs enabled:
RasPlex:~ # vcgencmd codec_enabled MPG2
MPG2=enabled
RasPlex:~ # vcgencmd codec_enabled WVC1
WVC1=enabled
Issue:
Just installed RasPlex for the first time and attempted to use the NextPVR channel.  The channel works on all my other plex installations...
- Samsung Smart TV
- Windows PCs
- Android Phones
- Roku
- PleXBMC
I can't play any live channels or recordings.  I immediately get the following error.  No attempt at buffering first or anything.
"Please check that this file exists and the necessary drive is mounted"
Log: attached. Includes only the info from the failed request, I think.
I've seen previous topics where people had issues due to not having codecs, but I have them enabled.  Is this maybe some firewall issue on the RasPlex side?
Thanks,
Klobersaurus
Looking at the logs, I want to say that the issue is that the plugin is looking at 127.0.0.1 as the IP, but every time I try to change the IP to my Plex server's IP, it doesn't take.  It just resets it back to 127.0.0.1.
However...
1. It doesn't seem to matter for all of my other clients
2. I'm not sure I understand whether this IP (127.0.0.1) in the logs is coming from the server making a request to itself or the client making a request to the server.
