No audio after the first boot
Hello,
I have an audio issue with my Raspberry 2 @ Rasplex 0.7.1. After writing the .img file to SD and booting for the first time, audio works fine. But after restarting the OS neither 3.5mm audio nor hdmi audio will work.
What options have you selected for Audio Output in Preferences->System?
Regards
I tested both HDMI and Analog.
Suggest you reflash the card.
Regards
I already tried this a few times, the problem is reproducible.
Unfortunately it’s not reproducible for me (or thousands of other users), can you try an earlier release? It may be your hardware.
Regards
