Not sure what happened but got a recording with no audio track:
Metadata:
ENCODER : Lavf57.72.100
Duration: 00:53:54.32, start: 0.000000, bitrate: 4165 kb/s
Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 1k tbn, 50 tbc (default)
Metadata:
DURATION : 00:53:54.320000000
Stream #0:1(eng): Subtitle: dvb_subtitle (default)
Metadata:
DURATION : 00:53:44.879000000
I’ve attached the Plex XML. I’m running 1.73 with an HDHomeRun.
I’m in the USA and have the same issue with both live tv watching and recording…No Audio
Setup is AVERMEDIA Volar Hybrid Q
Shield TV Experience 5.2
Plex server version 1.7.2.3878(smb)
Video works great and recording works great, but no audio
Audio on non DVR media works fine
Sorry for bouncing this one back up. Got a recording at 9PM last night with no audio again. Log attached (this time, wasn’t able to get it last time) and file xml attached.
I dont record that much, but this is the first problem I’ve had in months.
it’s a known bug, that has been filed with plex, sorry no idea if/when it will be fixed.
