No Dolby Vision on new Shield Pro 2019
Hi, today I upgraded from Nvidia shield 2017 to the new Pro 2019.
I have activated Dolby Vision in the settings.
If I start a movie in HBO Max with Dolby Vision the DV icon is shown on my TV.
If i start a movie or tv show in Plex which have DV i just get regular HDR.
My TV (Sony XF9005) is ”smart” and i have Plex there too, if i start the same movie/tv show there the DV icon will show on the tv, so my content have Dolby Vision.
Is there a setting i should edit on the Shield?
As i said, HBO Max is working, so there should not be any problems with the cables or the receiver.
Any tips or should i provide logs?
Media server is running in a docker container on unraid server
Yeah this broke recently with an update
This is working fine for me. Was working in the latest release and currently on latest beta with no issues other than the known general playback problems.
Thanks, then it hopefully it will be solved in an update for me
Make sure your shield is plugged in a HDMI plugs that supports DV. They don’t always support the same codecs on the same TV.
