No EAE watchfolder set
Server Version#: 4.160.0
Player Version#: none
Hello i run plex un docker mint proxmox vm with RTX 3070 passthrough, and use Traefik to have HTTPS urls when accessed from LAN via Web browser.
I have this error, what could be done about it ?
If this is missing proprietary codec problem, can i buy it and inject it inside docker ?
Error opening output file track-0010.wav.
Error opening output files: Generic error in an external library
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x731cc3b80a00] stream 0, timescale not set
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/file.m4a':
  Metadata:
    major_brand     : M4A
    minor_version   : 1
    compatible_brands: isomM4A mp42
    creation_time   : 2023-02-04T15:38:01.000000Z
    title           :
    artist          :
    composer        :
    album           :
    genre           : Pop/General
    track           : 12/13
    disc            : 1/1
    date            : 2009-11-20T10:00:00Z
    rating          : 0
    media_type      : 1
    album_artist    :
    copyright       :
    comment         :
  Duration: 00:06:04.54, start: 0.000000, bitrate: 769 kb/s
  Stream #0:0[0x1](und): Audio: eac3 (Dolby Digital Plus + Dolby Atmos) (ec-3 / 0x332D6365), 48000 Hz, 5.1(side), 768 kb/s (default)
    Metadata:
      creation_time   : 2023-01-30T19:39:41.000000Z
      handler_name    : SoundHandler
      vendor_id       : [0][0][0][0]
    Side data:
      audio service type: main
  Stream #0:1[0x0]: Video: mjpeg (Baseline), yuvj420p(pc, bt470bg/unknown/unknown), 500x500 [SAR 1:1 DAR 1:1], 90k tbr, 90k tbn (attached pic)
[eac3_eae @ 0x731cc23eeb80] No EAE watchfolder set!
[aist#0:0/eac3 @ 0x731cc23f9880] Error while opening decoder: Generic error in an external library
[aost#0:0/pcm_s16le @ 0x731cc3b59340] Error initializing a simple filtergraph
Error opening output file track-0011.wav.
ffmpeg version 4987be2-8e3461d4c82193c06183af3f Copyright (c) 2000-2025 the FFmpeg developers
  built with Plex clang version 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
  configuration: --disable-static --enable-shared --disable-libx264 --disable-hwaccels --disable-protocol=concat --external-decoder=h264 --enable-debug --enable-muxers --enable-libxml2 --fatal-warnings --disable-gmp --disable-avdevice --disable-bzlib --disable-sdl2 --disable-decoders --disable-devices --disable-encoders --disable-ffprobe --disable-ffplay --disable-doc --disable-iconv --disable-lzma --disable-schannel --disable-linux-perf --disable-mediacodec --enable-eae --disable-protocol='udp,udplite' --arch=x86_64 --target-os=linux --strip=true --cc=x86_64-linux-musl-clang --pkg-config=/home/runner/_work/plex-conan/plex-conan/plexconantool/plex-pkg-config --pkg-config-flags=--static --windres=llvm-windres --enable-cuda-llvm --enable-libdrm --disable-beignet --enable-opencl --enable-cross-compile --ar=llvm-ar --nm=llvm-nm --ranlib=llvm-ranlib --extra-ldflags='-Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.8.1-0/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.22.0-0/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.8.1-0/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.22.0-0/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/lib -Wl,-rpath,/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/lib -m64 -L/home/runner/_work/plex-conan/plex-conan/.conan/data/opus/1.2.1-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libvorbis/1.3.5-44/plex/main/package/76eba14299c6c14bf4759b1da21aec07c9ca1a2f/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/dav1d/1.0.0-20/plex/main/package/4d954bcc6be6a68b775ef1b1bae9dd65e4e237ff/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/ffnvcodec/11.1.5.3-43d9170-1/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/x264/161-1086f45-34/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/zvbi/0.2.35-66/plex/main/package/7366a567f554439fb9e7a3415c9d1c2ea2b75360/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libass/0.17.3-6/plex/main/package/d81dbed7e8ad560c9ec55240308ceb55b203927d/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/mp3lame/3.98.4-38/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-media-driver/25.2.6-1/plex/main/package/bb11b771bdd2e73dbca3ba3fa4e91df6e323972a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-vaapi-driver/2.4.1-48/plex/main/package/54d41cda82931ea2b2be37156bad83b30007f4c5/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/opencl-icd-loader/v2024.05.08-861b68b-2/plex/main/package/421f4632684b64b7f88e2f734a2cb50980dd916d/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libogg/1.3.2-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/fribidi/1.0.12-7/plex/main/package/464531ac2a3f2ab2167bd10d1214603bc8116983/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/harfbuzz/4.2.1-11/plex/main/package/53415d552ac96104f622ffa8d8530937a40b4271/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.22.0-0/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.8.1-0/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/fontconfig/2.14.0-11/plex/main/package/aacc2a7710dfa87ed80d4eea45b80c93243fe456/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libxml2/2.9.11-e1bcffea-19/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/freetype2/2.12.1-32/plex/main/package/82a00e1e4cc2e8878bb79ae9b5e2235fd8280e6a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/expat/2.6.4-1/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libuuid/1.0.3-33/plex/main/package/841d526523d3550ac4d52807df94cbbedce37e2c/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libpthread-stubs/0.4-40/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/bzip2/1.0.6-43/plex/main/package/618bb3c469051b52e1349cf1a297263df374d15a/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/libpng/1.6.37-47/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/lib -L/home/runner/_work/plex-conan/plex-conan/.conan/data/zlib/1.2.11-37/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/lib -Wl,--gc-sections -Wl,-z,noexecstack -Wl,-z,relro -g2 -gdwarf-4 -Wl,--build-id=sha1 -flto=thin -fwhole-program-vtables -Wl,--icf=all -Wl,--threads=6 -Wl,-O2 -l:libgcompat.so.0 -Wl,-rpath,'\''XORIGIN/../lib'\'' -Wl,-rpath,'\''XORIGIN/lib'\'' -Wl,--thinlto-cache-dir=/home/runner/_work/plex-conan/plex-conan/.conan/data/ffmpeg/6.1-4987be2add-2/plex/main/build/ae3865a0a9e06d4f7b5469a816af94f4d1ca3878/lto_cache/' --extra-libs= --enable-decoder=png --enable-decoder=apng --enable-decoder=bmp --enable-decoder=mjpeg --enable-decoder=thp --enable-decoder=gif --enable-decoder=dirac --enable-decoder=ffv1 --enable-decoder=ffvhuff --enable-decoder=huffyuv --enable-decoder=libdav1d --enable-decoder=av1 --enable-decoder=rawvideo --enable-decoder=zero12v --enable-decoder=ayuv --enable-decoder=r210 --enable-decoder=v210 --enable-decoder=v210x --enable-decoder=v308 --enable-decoder=v408 --enable-decoder=v410 --enable-decoder=y41p --enable-decoder=yuv4 --enable-decoder=ansi --enable-decoder=alac --enable-decoder=flac --enable-decoder=vorbis --enable-decoder=opus --enable-decoder=pcm_f32be --enable-decoder=pcm_f32le --enable-decoder=pcm_f64be --enable-decoder=pcm_f64le --enable-decoder=pcm_lxf --enable-decoder=pcm_s16be --enable-decoder=pcm_s16be_planar --enable-decoder=pcm_s16le --enable-decoder=pcm_s16le_planar --enable-decoder=pcm_s24be --enable-decoder=pcm_s24le --enable-decoder=pcm_s24le_planar --enable-decoder=pcm_s32be --enable-decoder=pcm_s32le --enable-decoder=pcm_s32le_planar --enable-decoder=pcm_s8 --enable-decoder=pcm_s8_planar --enable-decoder=pcm_u16be --enable-decoder=pcm_u16le --enable-decoder=pcm_u24be --enable-decoder=pcm_u24le --enable-decoder=pcm_u32be --enable-decoder=pcm_u32le --enable-decoder=pcm_u8 --enable-decoder=pcm_alaw --enable-decoder=pcm_mulaw --enable-decoder=ass --enable-decoder=dvbsub --enable-decoder=dvdsub --enable-decoder=ccaption --enable-decoder=pgssub --enable-decoder=jacosub --enable-decoder=microdvd --enable-decoder=movtext --enable-decoder=mpl2 --enable-decoder=pjs --enable-decoder=realtext --enable-decoder=sami --enable-decoder=ssa --enable-decoder=stl --enable-decoder=subrip --enable-decoder=subviewer --enable-decoder=text --enable-decoder=vplayer --enable-decoder=webvtt --enable-decoder=xsub --enable-decoder=eac3_eae --enable-decoder=truehd_eae --enable-decoder=mlp_eae --enable-encoder=flac --enable-encoder=alac --enable-encoder=libvorbis --enable-encoder=libopus --enable-encoder=mjpeg --enable-encoder=png --enable-encoder=rawvideo --enable-encoder=wrapped_avframe --enable-encoder=ass --enable-encoder=dvbsub --enable-encoder=dvdsub --enable-encoder=movtext --enable-encoder=ssa --enable-encoder=subrip --enable-encoder=text --enable-encoder=webvtt --enable-encoder=xsub --enable-encoder=pcm_f32be --enable-encoder=pcm_f32le --enable-encoder=pcm_f64be --enable-encoder=pcm_f64le --enable-encoder=pcm_s8 --enable-encoder=pcm_s8_planar --enable-encoder=pcm_s16be --enable-encoder=pcm_s16be_planar --enable-encoder=pcm_s16le --enable-encoder=pcm_s16le_planar --enable-encoder=pcm_s24be --enable-encoder=pcm_s24le --enable-encoder=pcm_s24le_planar --enable-encoder=pcm_s32be --enable-encoder=pcm_s32le --enable-encoder=pcm_s32le_planar --enable-encoder=pcm_u8 --enable-encoder=pcm_u16be --enable-encoder=pcm_u16le --enable-encoder=pcm_u24be --enable-encoder=pcm_u24le --enable-encoder=pcm_u32be --enable-encoder=pcm_u32le --enable-encoder=h264_vaapi --enable-encoder=hevc_vaapi --enable-encoder=h264_nvenc --enable-encoder=hevc_nvenc --enable-encoder=eac3_eae --enable-hwaccel=av1_vaapi --enable-hwaccel=av1_nvdec --prefix=/home/runner/_work/plex-conan/plex-conan/.conan/data/ffmpeg/6.1-4987be2add-2/plex/main/build/ae3865a0a9e06d4f7b5469a816af94f4d1ca3878/transcoder-install --enable-openssl --enable-libass --enable-libopus --enable-libvorbis --enable-libdav1d --extra-cflags='-m64 -O3 -fdata-sections -ffunction-sections -fno-omit-frame-pointer -g2 -gdwarf-4 -fcommon -flto=thin -fwhole-program-vtables -I/home/runner/_work/plex-conan/plex-conan/.conan/data/opus/1.2.1-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libvorbis/1.3.5-44/plex/main/package/76eba14299c6c14bf4759b1da21aec07c9ca1a2f/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/dav1d/1.0.0-20/plex/main/package/4d954bcc6be6a68b775ef1b1bae9dd65e4e237ff/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/ffnvcodec/11.1.5.3-43d9170-1/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/openssl/3.1.1-2cf4e90-6/plex/main/package/121b5d655884b039b2c06c747f3d73ef7b698b66/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/x264/161-1086f45-34/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/zvbi/0.2.35-66/plex/main/package/7366a567f554439fb9e7a3415c9d1c2ea2b75360/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libass/0.17.3-6/plex/main/package/d81dbed7e8ad560c9ec55240308ceb55b203927d/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/mp3lame/3.98.4-38/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-media-driver/25.2.6-1/plex/main/package/bb11b771bdd2e73dbca3ba3fa4e91df6e323972a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libogg/1.3.2-39/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/iconv/1.16-37/plex/main/package/da4999666f4b1709dd93ae40fffdb2c6f130b23f/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/fribidi/1.0.12-7/plex/main/package/464531ac2a3f2ab2167bd10d1214603bc8116983/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/harfbuzz/4.2.1-11/plex/main/package/53415d552ac96104f622ffa8d8530937a40b4271/include/harfbuzz -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libva/2.22.0-0/plex/main/package/f0f4893209b867ce448a96e25ef4d6b158311557/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/intel-gmmlib/22.8.1-0/plex/main/package/d7d5d1f35ff92a8c39da6b47605055e839a42a9c/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/opencl-headers/v2024.05.08-8275634-1/plex/main/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/fontconfig/2.14.0-11/plex/main/package/aacc2a7710dfa87ed80d4eea45b80c93243fe456/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libdrm/2.4.120-6/plex/main/package/678777ee2ca8706ca90cf805e0dd88235f6d7f05/include/libdrm -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libxml2/2.9.11-e1bcffea-19/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libxml2/2.9.11-e1bcffea-19/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/include/libxml2 -I/home/runner/_work/plex-conan/plex-conan/.conan/data/freetype2/2.12.1-32/plex/main/package/82a00e1e4cc2e8878bb79ae9b5e2235fd8280e6a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/expat/2.6.4-1/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libuuid/1.0.3-33/plex/main/package/841d526523d3550ac4d52807df94cbbedce37e2c/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libpciaccess/0.17-7/plex/main/package/7763a87432c78a82fd36373080b064286892cea3/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/bzip2/1.0.6-43/plex/main/package/618bb3c469051b52e1349cf1a297263df374d15a/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/libpng/1.6.37-47/plex/main/package/33406d37abb556848190dcd6097a9849aa894baf/include -I/home/runner/_work/plex-conan/plex-conan/.conan/data/zlib/1.2.11-37/plex/main/package/64edc78a49b81c2615dad7b22a9ac90cc029860a/include -DLIBXML_STATIC -DFRIBIDI_LIB_STATIC -DNDEBUG'
  libavutil      58. 29.100 / 58. 29.100
  libavcodec     60. 31.102 / 60. 31.102
  libavformat    60. 16.100 / 60. 16.100
  libavfilter     9. 12.100 /  9. 12.100
  libswscale      7.  5.100 /  7.  5.100
  libswresample   4. 12.100 /  4. 12.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x75d90ce80a00] stream 0, timescale not set
  Metadata:
    major_brand     : M4A
    minor_version   : 1
    creation_time   : 2023-02-04T15:38:06.000000Z
    title           :
    artist          :
    composer        :
    album           :
    genre           : Pop/General
    track           : 13/13
    disc            : 1/1
    rating          : 0
    media_type      : 1
    album_artist    :
  Duration: 00:04:16.19, start: 0.000000, bitrate: 770 kb/s
    Metadata:
      creation_time   : 2023-01-30T19:39:33.000000Z
    Side data:
[eac3_eae @ 0x75d90b6eeb80] No EAE watchfolder set!
[aist#0:0/eac3 @ 0x75d90b6f9880] Error while opening decoder: Generic error in an external library
[aost#0:0/pcm_s16le @ 0x75d90ce59340] Error initializing a simple filtergraph
Error opening output file track-0012.wav.
services:
  plex:
    extends:
      file: ../_common/gpu.yml
      service: all
    container_name: ${C_PX}
    image: ${C_PX_IMG}
    environment:
      - PLEX_CLAIM=${PLEX_CLAIM}
      - PLEX_PASS=${PLEX_PASS}
      - ADVERTISE_IP=${PLEX_ADVERTISE_IP}
      - CHANGE_CONFIG_DIR_OWNERSHIP=true #false
      - DEBUG=false #true
    volumes:
      # data + tmp
      - vol-plex:/config
      - type: volume
        source: vol-plex
        target: /tmp
        volume:
          subpath: tmp
      # media
      - vol-mp3:/music/mp3
      - vol-flac:/music/flac
      - vol-film:/film
      - vol-serie:/serie
      # localtime + logs + cache/temp
      - /etc/localtime:/etc/localtime
      - "${REP_LOGS}/${C_PX}:/config/Library/Application Support/Plex Media Server/Logs"
      - ${REP_CACHE}/${C_PX}:/transcode
    hostname: ${C_PX_HOST}
    networks:
      proxy:
      mvlan:
        ipv4_address: ${NET_LAN}.${C_PX_NUM}
        mac_address: ${MAC_LAN}:${C_PX_MAC}
networks:
  mvlan:
    external: true
  proxy:
    external: true
volumes:
  vol-plex:
    external: true
  vol-mp3:
    external: true
  vol-flac:
    external: true
  vol-film:
    external: true
  vol-serie:
    external: true
