Server Version#: 1.13.5.5291
Player Version#: newest ios-App, newest Fire-TV Stick (Gen2) App 7.3.2.6276
Windows Version#: 10 Pro 1803 Build 17134.228
For a week, h265 movies are no longer decoded / encoded by the graphics card (Geforce GTX 970). I had the hardware (CPU, motherboard and RAM) exchanged a week ago. Since then, the H265 movies are no longer running. H264 and VC-1 are no problem. Driver of the Geforce is up to date.
okay, the GTX 970 can not decode H265, but Plex would have to go back to software decoding.
The CPU utilization is only at a maximum of 2% and then will be encoded nothing.
What exactly is happening ? Have you got no video or playback fails ?
Your server should decode HEVC in software and encode in H264 in Hardware.
Maybe try another player (Plex web), is it same result ? Also try with hardware acceleration disabled in PMS advanced settings, see if playback works then.
