Server Version#: 1.25.9.5721
Tuner Make/Model: Hauppauge WinTV-dualHD
Using XMLTV?: No
Channel number/Name: 101-107
Hi I have recently bought the supported Hauppauge WinTV-dualHD and set it up using my plex server, however it doesn’t seem to receive any HD channels. I have tried it using the included software on another machine and it picks them up fine (this is using the same aerial). I have also tried it on the same machine using TVHeadend and it works perfectly. Is there something I am missing.
I am running plex in docker using the official docker image, if that is needed information, the USB is passed through using docker compose. The passthrough is working as it does get some channels but not all of them. This is also how TVHeadend is running with a similar passthrough (Not at the same time, only for testing)
Tom
