No HD Channels but I get them on Kaffine Media Player
Server Version#: 1.41.6.9685
Player Version#: 1.109.0.329-ea562b95
Tuner Make/Model: Hauppauge WinTV-DualHD
Guide/Lineup name: ??
Using XMLTV?: No
Channel number/Name: HD Channels
Setting up my Hauppauge WinTV-DualHD tuner for Plex.
I’m running a Ubuntu 24.04 with the latest plex media server.
I’ve installed Kaffine media player to check my tuner works and I get all my standard SD and HD for me in my area (In the UK, NG5).
Going through the setup for tuner on Plex, I only get SD channels. I try a different postcode (NG4, NG1), however these give me less channels with no HD channels.
Anything I’m doing wrong for the setup on Plex?
Just made a 22.04 VM and assigned the tuner to to that. Setup TVheadend and Antennas, all working fine.
If you are able to setup Plex on 22.04, not 24.04, I would suggest it since that is the lastest version of Ubuntu that hauppague supports with this tuner.
Link to setup page of both Tvheadend and Antennas as docker containers:
