PlexConnect cannot open "Home Movies" Library in Shared Libraries
Hello there everyone! I am currently having a little bit of trouble getting the Home Movies library working in PlexConnect!
One of the main issues I am currently having that I believe is unrelated to this is that I am running PlexConnect on a VPS that is not on the same local network as the PMS. It gives me an "Unauthorized" Error whenever I attempt to use it so it is useless to connect locally. I can however connect using my Plex.tv account, so I do that then just go to "Shared Libraries" and everything works fine. I do believe its not an error that I need to worry about and so I am not doing anything about it.
04:32:35 PlexAPI: No Response from Plex Media Server
04:32:35 PlexAPI: We failed to reach a server. Reason: Unauthorized
The main error that I am having an issue with is that whenever I attempt to access the "Home Movies" section it gives me the error below. I am not sure what I can do about it so I knew to post it here. I am on the latest commit.
04:29:48 DNSServer: Source: ('(Apple TV IP Address)', 56475)
04:29:48 DNSServer: Domain: trailers.apple.com
04:29:48 DNSServer: ***intercept request
04:29:48 DNSServer: -> DNS response: (VPS IP Address)
04:29:48 WebServer: serving .xml: /library/sections/21
04:29:48 WebServer: serving .xml: /library/sections/21/recentlyAdded
04:29:48 WebServer: File Not Found:
Traceback (most recent call last):
  File "/root/PlexConnect/WebServer.py", line 229, in do_GET
    XML = XMLConverter.XML_PMS2aTV(PMSaddress, self.path + query, options)
  File "/root/PlexConnect/XMLConverter.py", line 381, in XML_PMS2aTV
    aTVTree = etree.parse(sys.path[0]+'/assets/templates/'+XMLtemplate)
  File "", line 62, in parse
  File "", line 26, in parse
IOError: [Errno 21] Is a directory: '/root/PlexConnect/assets/templates/'
I am running CentOS 6.5 and Python 2.7.
Here is a picture of the Shared Libraries List:
Please post a log of the issue, with loglevel setting "High".
Here is a full log of the issue as well as a partial log of where the DNS request started to be received. The full log is also in the Gist. I have removed the three IP addresses.
https://gist.github.com/OstlerDev/fbeb02a9bb4e7d3283a4#file-partial-log-from-request
Thank you for your quick response!
>>08:36:56 ATVLogger: atv.onGenerateRequest done: http://trailers.apple.com/PMS((PMSIP):32400)/library/sections/21? PlexConnect=Extended_Personal_Media_Scanner&PlexConnectUDID=F0TMK928FF54&PlexConnectATVName=Apple%20TV
The used scanner is not known, and there is not real defaulting to a section type/template directory for such a case...
Are you able to modify XMLConverter.py, line 343, as shown? Please give it a try and report back -
 339   elif cmd.find('Scanner') != -1:
 340       dprint(__name__, 1, "Found Scanner.")
 341       if cmd.find('Series') != -1: dir = 'TVShow'
 342       elif cmd.find('Movie') != -1: dir = 'Movie'
 343       elif cmd.find('Video') != -1 or cmd.find('Personal_Media') != -1: dir = 'HomeVideo'
 344       elif cmd.find('Premium_Music') != -1: dir = 'Music'
 345       elif cmd.find('Photo') != -1: dir = 'Photo'
 346       elif cmd.find('Music') != -1 or cmd.find('iTunes') != -1: dir ='Music'
 347       cmd = 'NavigationBar'
PS: Not sure, why we check for string "Premium_Music" here, too, as it should have been covered with line 346 already?
Because when I added commit f9d8d30 Quick fix to get Premium Music section to work... I didn't know at that time weather or not the Premium Music sections would need there own set of templates. Turns out they didn't.... But hey if it makes you happy go ahead and change it.
I will edit the file and try it now then post my results as an edit to this post.
EDIT: Changing Line 343 to the updated one you provided fixes the issue that I was seeing! I do however get another issue. If I browse by folder in there it works fine, but when I press the menu button it gives the "Trailers is not Available" error. Not a huge deal so I wouldn't worry about looking into it but your fix works! Must have just been an unknown scanner needing to be added. I have submitted a pull request with the fixed code. It can be found here: https://github.com/iBaa/PlexConnect/pull/347
Menu button as in "one step back"?
Roidy, do you have an idea, why this would result in "Trailers not Available"?
Yes, upon entering a tiered folder and browsing the video it gives me that error when I attempt to go one step back. If you would like a full log I can provide as well.
Log is good... essentially the part when requesting the "step back".
The only thing that triggers on a menu "step back" is a call to the "onVolatileReload".
Here is the full log you requested along with the partial log of where I believe the error occurred: https://gist.github.com/OstlerDev/17a1a4327717a3826a9e
This is the error it produces. Very similar to the one mentioned in the original post.
20:53:38 WebServer: File Not Found:
Man, you got a buggy version there. :-D
In /assets/templates/HomeVideo/ByFolder.xml edit line 7 - it looks like the Underscore went missing in "HomeVideo_ByFolder":
Interesting that nobody else complained about those things.
Awesome! Adding that underscore back in there fixed the issue and it all works smoothly now! Thanks a ton!
