No match frame rate setting?
i’ve picked up a new Appletv, installed plex.
having had it installed on a shield previously i notice the appletv client doesn’t have a “refresh rate switching” setting within the plex client settings.
does this mean that, as long as the “match frame rate” setting in the appletv itself is enabled then plex will play content at the correct frame rate?
also noticed there is no “allow insecure connections on same network” setting on the appletv client either.
no-one ?
