So I just bought my plex pass today and I may have missed the memo but I was under the impression that Plex could combine the multiple tuners during the Live TV and DVR set up? Plex sees both of my hdhomerun primes but when I go to click on the tuners it is only letting me click one at a time. How do I combine the two?
I don’t think this is currently possible. At least I haven’t been able to achieve this after 2 hours messing around with 2 sep turners
Well it looks like I have to set up one tuner at a time but I do see both of them listed. Whether both of them are accessible simultaneously is a different story. I’ll have to test it out.
How did your test go? I have 2 Primes as well. Did you find all six tuners can be concurrently accessed?
I haven’t had a case where I was using all 6 simultaneously. The most I’ve used at the same time (that I can recall) is 4. I assume if Plex can use 4 tuners across two Primes then there shouldn’t be a reason why it cannot use 6.
There should not be a problem using all Tuners on both devices. In the past I have had four different HDHR tuner devices (2 Connects and 2 Extends) configured on one server and have been able to record more than 6 shows at the same time during testing.
