No option to fast forward or quick skip using CarPlay
I’ve recently purchased a lifetime subscription as I’m a massive fan of Plex and was really excited to use Plexamp, especially with CarPlay.
One thing I’ve been unable to get working is the ability to fast forward or quick skip the track forward.
I’ve tried using both holding the fast forward button on the screen and also the physical button on the steering wheel but neither works.
I’ve also tried using Siri to skip forward 30 seconds or a minute but that also struggles but does end up skipping about 10 seconds no matter what length I ask it.
All of this functionality seems to work in other apps so I’m hoping it’s something that can be resolved.
I don’t want to sound like I’m nitpicking because what your team has done is truly unreal and I hope this is an easy fix. I’ve also attached a log if it helps.
Plexamp-Logs-2022-10-02-1.zip (764.8 KB)
