Server Version#: 1.13.9.5456
Player Version#: latest LG and Web
When I attempt to play a particular video on either the web player or the WebOS version of the Plex player for LG, Plex always transcodes it and never allows it to be played in “original quality”. PMS is on the same subnet as the devices on which I’ve attempted playing the video and connected by 1Gbps cables.
I should note that other videos can be played in original quality and the issue I’m having affects a particular video.
The video itself has the following format: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc
Extra info extracted by ffmpeg:
ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers
built with gcc 7 (Ubuntu 7.3.0-16ubuntu3)
configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
libavutil 55. 78.100 / 55. 78.100
libavcodec 57.107.100 / 57.107.100
libavformat 57. 83.100 / 57. 83.100
libavdevice 57. 10.100 / 57. 10.100
libavfilter 6.107.100 / 6.107.100
libavresample 3. 7. 0 / 3. 7. 0
libswscale 4. 8.100 / 4. 8.100
libswresample 2. 9.100 / 2. 9.100
libpostproc 54. 7.100 / 54. 7.100
[matroska,webm @ 0x5631508d2760] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[matroska,webm @ 0x5631508d2760] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Input #0, matroska,webm, from '../film/THE_VIDEO/THE_VIDEO.mkv':
Metadata:
encoder : libebml v1.3.5 + libmatroska v1.4.8
creation_time : 2018-03-16T17:12:57.000000Z
Duration: 02:31:51.71, start: 0.000000, bitrate: 50582 kb/s
Chapter #0:0: start 0.000000, end 18.643000
Metadata:
title : Chapter 1
Chapter #0:1: start 18.643000, end 105.730000
Metadata:
title : Chapter 2
Chapter #0:2: start 105.730000, end 191.816000
Metadata:
title : Chapter 3
Chapter #0:3: start 191.816000, end 463.296000
Metadata:
title : Chapter 4
Chapter #0:4: start 463.296000, end 768.434000
Metadata:
title : Chapter 5
Chapter #0:5: start 768.434000, end 824.573000
Metadata:
title : Chapter 6
Chapter #0:6: start 824.573000, end 989.279000
Metadata:
title : Chapter 7
Chapter #0:7: start 989.279000, end 1199.281000
Metadata:
title : Chapter 8
Chapter #0:8: start 1199.281000, end 1371.369000
Metadata:
title : Chapter 9
Chapter #0:9: start 1371.369000, end 1564.980000
Metadata:
title : Chapter 10
Chapter #0:10: start 1564.980000, end 1642.849000
Metadata:
title : Chapter 11
Chapter #0:11: start 1642.849000, end 1884.757000
Metadata:
title : Chapter 12
Chapter #0:12: start 1884.757000, end 1974.681000
Metadata:
title : Chapter 13
Chapter #0:13: start 1974.681000, end 2127.667000
Metadata:
title : Chapter 14
Chapter #0:14: start 2127.667000, end 2291.497000
Metadata:
title : Chapter 15
Chapter #0:15: start 2291.497000, end 2513.427000
Metadata:
title : Chapter 16
Chapter #0:16: start 2513.427000, end 2669.541000
Metadata:
title : Chapter 17
Chapter #0:17: start 2669.541000, end 2811.475000
Metadata:
title : Chapter 18
Chapter #0:18: start 2811.475000, end 3101.932000
Metadata:
title : Chapter 19
Chapter #0:19: start 3101.932000, end 3230.060000
Metadata:
title : Chapter 20
Chapter #0:20: start 3230.060000, end 3341.504000
Metadata:
title : Chapter 21
Chapter #0:21: start 3341.504000, end 3459.581000
Metadata:
title : Chapter 22
Chapter #0:22: start 3459.581000, end 3556.636000
Metadata:
title : Chapter 23
Chapter #0:23: start 3556.636000, end 3725.847000
Metadata:
title : Chapter 24
Chapter #0:24: start 3725.847000, end 3787.700000
Metadata:
title : Chapter 25
Chapter #0:25: start 3787.700000, end 3941.729000
Metadata:
title : Chapter 26
Chapter #0:26: start 3941.729000, end 4023.477000
Metadata:
title : Chapter 27
Chapter #0:27: start 4023.477000, end 4225.721000
Metadata:
title : Chapter 28
Chapter #0:28: start 4225.721000, end 4410.322000
Metadata:
title : Chapter 29
Chapter #0:29: start 4410.322000, end 4663.450000
Metadata:
title : Chapter 30
Chapter #0:30: start 4663.450000, end 4853.056000
Metadata:
title : Chapter 31
Chapter #0:31: start 4853.056000, end 5057.969000
Metadata:
title : Chapter 32
Chapter #0:32: start 5057.969000, end 5183.219000
Metadata:
title : Chapter 33
Chapter #0:33: start 5183.219000, end 5279.524000
Metadata:
title : Chapter 34
Chapter #0:34: start 5279.524000, end 5449.360000
Metadata:
title : Chapter 35
Chapter #0:35: start 5449.360000, end 5574.568000
Metadata:
title : Chapter 36
Chapter #0:36: start 5574.568000, end 5753.706000
Metadata:
title : Chapter 37
Chapter #0:37: start 5753.706000, end 5830.616000
Metadata:
title : Chapter 38
Chapter #0:38: start 5830.616000, end 5952.863000
Metadata:
title : Chapter 39
Chapter #0:39: start 5952.863000, end 6127.663000
Metadata:
title : Chapter 40
Chapter #0:40: start 6127.663000, end 6303.714000
Metadata:
title : Chapter 41
Chapter #0:41: start 6303.714000, end 6575.694000
Metadata:
title : Chapter 42
Chapter #0:42: start 6575.694000, end 6740.608000
Metadata:
title : Chapter 43
Chapter #0:43: start 6740.608000, end 6964.749000
Metadata:
title : Chapter 44
Chapter #0:44: start 6964.749000, end 7132.083000
Metadata:
title : Chapter 45
Chapter #0:45: start 7132.083000, end 7391.133000
Metadata:
title : Chapter 46
Chapter #0:46: start 7391.133000, end 7599.758000
Metadata:
title : Chapter 47
Chapter #0:47: start 7599.758000, end 7903.604000
Metadata:
title : Chapter 48
Chapter #0:48: start 7903.604000, end 8112.103000
Metadata:
title : Chapter 49
Chapter #0:49: start 8112.103000, end 8416.699000
Metadata:
title : Chapter 50
Chapter #0:50: start 8416.699000, end 8619.694000
Metadata:
title : Chapter 51
Chapter #0:51: start 8619.694000, end 9111.711000
Metadata:
title : Chapter 52
Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)
Metadata:
BPS-eng : 45913506
DURATION-eng : 02:31:51.695000000
NUMBER_OF_FRAMES-eng: 218462
NUMBER_OF_BYTES-eng: 52293733337
_STATISTICS_WRITING_APP-eng: mkvmerge v21.0.0 ('Tardigrades Will Inherit The Earth') 64-bit
_STATISTICS_WRITING_DATE_UTC-eng: 2018-03-16 17:12:57
_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default)
Metadata:
BPS-eng : 3941380
DURATION-eng : 02:31:51.663000000
NUMBER_OF_FRAMES-eng: 10933986
NUMBER_OF_BYTES-eng: 4489066120
Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s
Metadata:
BPS-eng : 640000
DURATION-eng : 02:31:51.680000000
NUMBER_OF_FRAMES-eng: 284740
NUMBER_OF_BYTES-eng: 728934400
Stream #0:3(rum): Subtitle: subrip (default)
Metadata:
BPS-eng : 43
DURATION-eng : 02:23:34.826000000
NUMBER_OF_FRAMES-eng: 1595
NUMBER_OF_BYTES-eng: 46333
Stream #0:4(eng): Subtitle: hdmv_pgs_subtitle
Metadata:
BPS-eng : 30863
DURATION-eng : 02:23:23.020000000
NUMBER_OF_FRAMES-eng: 3796
NUMBER_OF_BYTES-eng: 33189478
Stream #0:5(spa): Subtitle: hdmv_pgs_subtitle
Metadata:
BPS-eng : 25741
DURATION-eng : 02:22:40.561000000
NUMBER_OF_FRAMES-eng: 3182
NUMBER_OF_BYTES-eng: 27545633
