What’s the minimum version of OS X that OpenPHT works on? I tried it on my Mac Mini HTPC that runs OS X 10.6.8, but OpenPHT just quits on launch.
Starting with OpenPHT 1.6.0 we bumped the minimum version of OS X to 10.7 to keep in line with Kodi Jarvis.
Suggest you try the 1.5.2 32-bit build from https://github.com/RasPlex/OpenPHT/issues/52#issuecomment-215587798 at the moment.
@Kwiboo said:
Starting with OpenPHT 1.6.0 we bumped the minimum version of OS X to 10.7 to keep in line with Kodi Jarvis.Suggest you try the 1.5.2 32-bit build from OPHT 1.5.2 32-bit Crashing on OSX 10.6.8 · Issue #52 · RasPlex/OpenPHT · GitHub at the moment.
Sadly, that build doesn’t work on my setup. Oh well, I’ll just keep using the last compatible version of PHT. Thanks.
Then please don’t upgrade your server to PMS 1.0.0, it broke a number of things in PHT.
You could flash the OpenPHT embedded to a USB stick and boot from that, this would leave your SL hard drive intact but means you can run the latest version. Or upgrade the OS on your Mac Mini.
Regards
Well my server is screwed. I been running off a first gen mac mini Snow Leopard. Looks like it automatically updated. Any way I can downgrade from the latest update?
OpenPHT screwed your server, how?
