Does anybody know why my pictures are not showing?
Did you move the Plex data folder under Windows to a drive which is not formatted in NTFS or onto a network share?
https://support.plex.tv/hc/en-us/articles/201424327-Why-do-I-get-metadata-but-no-images-for-my-library-items-
You have selected source Database for movie in plex options ?
Now all my libarys are also gone?
@OttoKerner said:
@goeiste said:
Does anybody know why my pictures are not showing?Did you move the Plex data folder under Windows to a drive which is not formatted in NTFS or onto a network share?
I did move my Decoder direrctory because my SSD harddrive kept on running full.
But my D:| disk is NTFS formatted
@trumpy81 said:
Open Plex and go to settings->server->help and click on the download logs button. Attach the .zip you download to your next post please.
Now also all my librarys are gone?
How did you tell Plex that you moved it?
Are you 100% sure that you only moved the subfolder
C:\Users\<username>\AppData\Local\Plex Media Server\Cache
and not also all the other subfolders underneath
C:\Users\<username>\AppData\Local\Plex Media Server ?
How much space is now left on drive C:\ ?
Side note:
Settings - Server - Network - (Show Advanced) - ‘List of IP addresses and networks that are allowed without auth’
contains ‘routable’/‘non-private’ IP addresses and is therefore ignored
@OttoKerner said:
@goeiste said:
I did move my Decoder direrctory because my SSD harddrive kept on running full.How did you tell Plex that you moved it?
C:\Users\<username>\AppData\Local\Plex Media Server\Cacheand not also all the other subfolders underneath
C:\Users\<username>\AppData\Local\Plex Media Server?How much space is now left on drive C:\ ?
Side note:
I did change it here: because only 1 gb left on my SSD C:\
My librarys are back but only showing pictures on new add items?
That’s correct then. All good ![]()
Moving the folders to the other drive did destroy the ‘symbolic links’ perhaps.
I think you have to refresh the affected movies.
Indeed I had to referesh them. How stupid and easy could it have been.
Thank you!
