No possibility to rate a song anymore
Hello folks,
I’m on the latest beta and I am missing the possibility to rate a song. Is this intentional or a bug?
It’s a bug. We are aware.
Ok, thanks for the info
I believe this is fixed in the Plex for Android 7.24.0.13403-beta:
  • [Mobile] Rating widget missing from music player.
Yes, it should be fixed in latest beta. If you can, take a look and let us know if it’s fixed for you as well. Thanks
It’s fixed and works as expected! Thanks :slight_smile:
great, you can mark this topic as solved then
