No poster & background selection
If I edit a movie, it doesn’t show me posters and backgrounds anymore to chose from. That never happened before. If I try to upload one, it tells me “there was an error uploading this artwork”. The rest works fine, metadata search and stuff.
I’m on Version 1.15.4.993
I’m having the same issue. I wonder if a server on their end is down?
Yep, same thing is happening to me.
There is someone else who also created a post on the same topic, so I am adding what I wrote there to this one:
I’m kind of having the same issue. I just added a movie and went in to change the poster for it, but when I click on the “Poster” link, the screen is blank. When I click on the “choose an image” link, select the artwork and click on “Open”, I get a message that says “there was an error uploading this artwork - try again”. When I try it again and continue to go through the process. now I’m not even getting the error message…it just stays blank.
Everything had been working fine and this is the first time I’ve tried to change an image since the app was updated to version 7.14.9954 on our Nvidia Shield the other day. I even tried access the web UI from a different computer to no avail.
I should have mentioned that it doesn’t matter if the artwork is for a movie or a TV series…the Poster screen is blank which also means nothing is showing from either TheMovieDB or TheTVDB sites.
Same problem here on version 1.15.3.876 running on nas4free. No selection available on poster, banner, or background. All the default images are showing in plex correctly, I just can’t select any images.
Indeed, it takes the default pictures correctly, but you can’t change them.
A fix was deployed to app.plex.tv
Yes, seems to work now. Thanks :+1:
