For some reason today when I go in to edit movies or TV shows no artwork or background images choices are showing up like they used to. Is anyone else experiencing this problem or no any reasons why nothing is showing up?
Thanks.
I’m kind of having the same issue. I just added a movie and went in to change the poster for it, but when I click on the “Poster” link, the screen is blank. When I click on the “choose an image” link, select the artwork and click on “Open”, I get a message that says “there was an error uploading this artwork - try again”. When I try it again and continue to go through the process. now I’m not even getting the error message…it just stays blank.
Everything had been working fine and this is the first time I’ve tried to change an image since the app was updated to version 7.14.9954 on our Nvidia Shield the other day. I even tried access the web UI from a different computer to no avail.
I should have mentioned that it doesn’t matter if the artwork is for a movie or a TV series…the Poster screen is blank which also means nothing is showing from either TheMovieDB or TheTVDB sites.
Also seeing this. PMS 1.15.4.993-bb4a2cb6c on Debian, multiple clients.
Fixed in the latest update today from Plex, refresh your web screen for Plex after the update, should be version Web Client 3.97.3
