When I try to edit my background, banner or poster art none of them will load. It shows the outline of the boxes and they quickly disappear without showing the artwork. I’ve updated to the latest Plex server update and it’s still doing this. Anyone else having this issue? I just added a new show and I don’t like the artwork that was automatically added and I can’t change it. It’s doing this in every single library I have for TV Shows, Movies and Home Videos.
After loading Plex in another browser (Microsoft Edge) I was able to see the artwork and change it, after going back to my main browser (Chrome) suddenly all the artwork is showing as normal where it was not before. So apparently by changing one image in a different browser it corrected the issue, very weird glitch. Anyone out there from Plex please keep and eye out for this issue in case it crops up again or gets worse.
Similar to this?
https://cloud.xatosch.de/index.php/s/Y5nQFMDoD6xbkdR
Thanks @Xatosch for the video.
@NewPlaza said:
Similar to this?
https://cloud.xatosch.de/index.php/s/Y5nQFMDoD6xbkdRThanks @Xatosch for the video.
That is EXACTLY what it was doing when I tried to change artwork! I’m glad I’m not the only one who experienced this.
There is another post in the PlexPass section(which you don’t have access to) with the same issue.
Here is a quote from someone who says this fixed it.
@eblkheart said:
I posted this on the other forum. This maybe a solution. It worked for me:
FIXED! I had a hunch all of a sudden. I am currently running adblock through Chrome (win10 x64). I decided to allow “ads” on https://app.plex.tv/* and when I did this, I reloaded the page. All of a sudden, it’s there. Everything including posters, banners, backgrounds showed up. I’m wondering if AdBlock has something that might be blocking this. Now on Firefox, I do not have AdBlock on it and everything was showing up. Something definitely to check into.
Let us know if this worked for you.
FIXED! I had a hunch all of a sudden. I am currently running adblock through Chrome (win10 x64). I decided to allow “ads” on https://app.plex.tv/* and when I did this, I reloaded the page. All of a sudden, it’s there. Everything including posters, banners, backgrounds showed up. I’m wondering if AdBlock has something that might be blocking this. Now on Firefox, I do not have AdBlock on it and everything was showing up. Something definitely to check into.Let us know if this worked for you.
I do use adblock in Chrome so maybe that’s a possibility. However I’ve been using adblock for years as I’ve been using Plex and never experienced this issue until today. Also I’ve not turned adblock off and Plex is loading everything fine even with it on, so who knows.
Was having the same problem as of this morning. This fixed my issue!!! Hooray!
Just started doing it again with the posters and banners not showing up. Set my ad blockers to greenlist plex.tv and now everything is loading. Just don’t enable them on the site and everything loads fine. Thanks for the info rlewandowski23.
