No recording of specific show
I’m pretty satisfied with plex DVR.
But I’ve one problem.
The series “Will & Grace” will be suggested and I can set a timer for it.
But the schedule list says there is no further broadcast although it is in the suggestions and also marked as a coming recording. Is it perhaps because of “&”?
Any suggestions for this?
Thanks!
Matthias
Make sure that you are not selecting new episodes only because at this time, all Will and Grace are currently repeats.
I selected on every channel, at any time, also rebroadcast
ok. found resolution… its the wrong season number.
season 1 is already on my drive. And the epg shows also season 1 instead of 10…
How can I delete my post?
