No remote access
Server Version#: Version 1.40.2.8395
Player Version#: Version 1.40.2.8395
I have remote access on and enable and on the local address it says that indeed I should be able to see my server outside of my local internet however I do not see it in my internal internet but can see it on my phones data.
I have an opnsense router with unbound dns on it however I tried all the tips from other forum posts everywhere and it didnt work.
Port forwarded correctly and everything.
I’m not quite sure I understand what you mean by that. Could you please explain this further?
I have remote access enabled as well but it doesn’t work. I know the reason though, perhaps it applies to your setup. I have a Netgear router with built in WiFi. When the cable company replaced my cable modem, they installed a cable modem with a built in WiFi router so I’m double-natted.
What are “all the tips”?
Was there one among these, which involved the string plex.direct? That’s most likely the crucial one.
