No Remote Network or transcoding
Server Version#: 1.16.5.1554
Two issues going on here, and will gladly separate into different threads:
  1. I recently installed the linuxserver/plex docker contianer onto my OMV server and followed Techno Dad life instructions. I had success with remote connection, but then installed TransmissionOVPN and have it vpn’ing into another country. At first my plex was routing through the same tunnel. I corrected this and cannot for the life of me figure out how to get remote connection working (no upnp, ports are forward). It will work for about 5 seconds before saying there is no connection
  2. I cannot get anything but direct play to work when playing films. The transcoder will spit out an error message to me and will not process anything. Nothing has changed and this has worked before. Plex Media Server Logs_2019-08-26_20-34-07.zip (4.5 MB)
I think I fixed the remote networking issue. It was pointing to the second ethernet card, instead of the one that I designated in the Network settings. Not sure why it defaulted the remote to the second card instead of the one I designated, but now the transcode is the main thing to fix
