No sound on Alexa WITH LOGS
I know this issue has been banging around on the forums for literally years.
But the bug is still there - is there a fix? Workaround? Anyone working on the issue?
My Alexa was fine yesterday, today I just get silence. It’s not the only alexa device I have issues with some have never worked.
I can use the command “alexa ask plex to play full moon fever” and it will respond with “Playing full moon fever by Tom Petty” but then silence. So it’s communicating with Plex but something breaks after that.
Using 1.24.1.4931 hosted on my Ubuntu server.
Just to add to the confusion it works on some alexa devices, but not others - all on the same network.
Use the Alexa app to delete the Plex skill. Then power cycle all of the Echos and reboot the server. Then re-enable the Plex skill via the Alexa app. For me, that process resolves, most of the time, the “finickiness” that I run into in my Alexa/Plex topology. Good luck!
Edit: I am assuming your server is running the latest Plex Media Server.
I found that 1st gen Echo ans Amazon Tap had the problem, but 2nd and 3rd gen Echo Dots played OK. See the other new topic started for this.
Maybe this:
Adding my frustration with silence here as well. I have two 2nd generation Echo’s running as a stereo pair with an Echo Sub. Always worked perfectly to have Alexa play music from PLEX from Windows 10 media server. For a long time now, Alexa recognizes the PC/Server, the song/album/artist titles, library radio, etc., it says it is now playing… then nothing ever happens, just silence. So frustrating. Doesn’t work at all. Used to work so great. Now I have two bookends and zero sound from my PLEX library going through the Echo devices. Talk to Alexa who responds perfectly, then… nothing. What changed? It is a PLEX pass feature now? An API issue? I don’t know where to turn. I’m going through the community threads and it appears I’m not alone. 10.22.2021
(google mail has been marking replies as spam so just noticed them).
I’ve tried the delete, reinstall skill and reboot. Worked once, but not again.
As towerpower points out, Alexa must be connecting to the plex server in order for the song/album search to work. Seems to be there is a bug in the streaming code.
Surprised plex don’t fix it, there is no way I would pay for software/plex pass if I know it’s buggy and they don’t fix issues in a timely manner.
Probably related: Plex not playing music on first generation Echo devices - #29 by goellnjh
Maybe if we can collate the info collected for the devs it’ll help resolve it faster. Can you guys report your generation echo devices?
We mostly have 3rd gen with one 1st gen.
They are all on the same account and the problem affects the 1st gen and one of the 3rd gen.
If the devs could tell me which are the correct logs and where they are located, I will a) post them here and b) take a look myself.
Doesn’t look good.
Starting Plex Media Server.
Critical: libusb_init failed
Connection to 178.79.149.70 closed by remote host.
__code__:194: FutureWarning: The behavior of this method will change in future versions. Use specific 'len(elem)' or 'elem is not None' test instead.
Connection to 139.162.247.112 closed by remote host.
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.24.3.5033-757abe6b4/PLEX MEDIA SCANNER/1e185efb-cbb4-4ef0-75c94e8e-938f63aa.dmp
root@gxxxxx:~# docker inspect -f '{{ index .Config.Labels "build_version" }}' plex
Linuxserver.io version:- 1.24.3.5033-757abe6b4-ls76 Build-date:- 2021-09-28T05:58:19+02:00
So, updated the image to
:~/docker-plex# docker inspect -f '{{ index .Config.Labels "build_version" }}' plexx
Linuxserver.io version:- 1.24.5.5173-8dcc73a59-ls84 Build-date:- 2021-11-02T04:58:29+01:00
Then tried to play a playlist. The Skill finds the playlist, displays the image but then after a few seconds ends. No sound. I can’t see anything obvious in the logs and they are set to DEBUG.
Nov 06, 2021 20:42:46.111 [0x7fd7c2e78b38] DEBUG - Content-Length is -1 (of total: -1).
Nov 06, 2021 20:42:52.435 [0x7fd7c2e78b38] DEBUG - Request: [34.255.195.252:9227 (WAN)] GET / (4 live) TLS Signed-in Token (garyandrew)
Nov 06, 2021 20:42:52.437 [0x7fd7c4b05b38] DEBUG - Completed: [34.255.195.252:9227] 200 GET / (4 live) TLS 2ms 5834 bytes
Nov 06, 2021 20:43:00.275 [0x7fd7c2e78b38] DEBUG - Request: [34.255.195.252:40646 (WAN)] GET /hubs/search?query=Gary&limit=25 (4 live) TLS Signed-in Token (garyandrew)
Nov 06, 2021 20:43:00.360 [0x7fd7c2e78b38] DEBUG - MetadataCounterCache: rebuilding full counter cache for totals
Nov 06, 2021 20:43:00.410 [0x7fd7c2e78b38] DEBUG - MetadataCounterCache: rebuilding full counter cache for views
Nov 06, 2021 20:43:00.416 [0x7fd7c2e78b38] DEBUG - There were 1 top-level paths for Mrs Brown's Boys.
Nov 06, 2021 20:43:00.418 [0x7fd7c4b05b38] DEBUG - Completed: [34.255.195.252:40646] 200 GET /hubs/search?query=Gary&limit=25 (4 live) TLS 143ms 20684 bytes
Nov 06, 2021 20:43:00.499 [0x7fd7c2e78b38] DEBUG - Request: [34.255.195.252:19101 (WAN)] POST /playQueues?type=audio&playlistID=11806&shuffle=0&repeat=0 (4 live) TLS Signed-in Token (garyandrew)
Nov 06, 2021 20:43:00.502 [0x7fd7c2e78b38] DEBUG - PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Nov 06, 2021 20:43:00.507 [0x7fd7c2e78b38] DEBUG - PlayQueue: Start index: 0 End index: 89 Count: 90
Nov 06, 2021 20:43:00.507 [0x7fd7c2e78b38] DEBUG - PlayQueue: 90 generated IDs compressed down to a 229 byte blob.
Nov 06, 2021 20:43:00.510 [0x7fd7c2e78b38] DEBUG - PlayQueue: Added 90 items in 0.0 sec.
Nov 06, 2021 20:43:00.551 [0x7fd7c2e78b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 06, 2021 20:43:00.551 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 12284 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.551 [0x7fd7c2e78b38] DEBUG - Audio Stream: 23886, Subtitle Stream: -1
Nov 06, 2021 20:43:00.551 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 13147 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.551 [0x7fd7c2e78b38] DEBUG - Audio Stream: 25339, Subtitle Stream: -1
Nov 06, 2021 20:43:00.552 [0x7fd7c2e78b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 06, 2021 20:43:00.552 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 12616 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.552 [0x7fd7c2e78b38] DEBUG - Audio Stream: 24543, Subtitle Stream: -1
Nov 06, 2021 20:43:00.552 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 12618 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.552 [0x7fd7c2e78b38] DEBUG - Audio Stream: 24546, Subtitle Stream: -1
Nov 06, 2021 20:43:00.553 [0x7fd7c2e78b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 06, 2021 20:43:00.553 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 13466 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.553 [0x7fd7c2e78b38] DEBUG - Audio Stream: 25745, Subtitle Stream: -1
Nov 06, 2021 20:43:00.553 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 13462 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.553 [0x7fd7c2e78b38] DEBUG - Audio Stream: 25741, Subtitle Stream: -1
Nov 06, 2021 20:43:00.554 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11423 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.554 [0x7fd7c2e78b38] DEBUG - Audio Stream: 22432, Subtitle Stream: -1
Nov 06, 2021 20:43:00.554 [0x7fd7c2e78b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 06, 2021 20:43:00.554 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11431 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.554 [0x7fd7c2e78b38] DEBUG - Audio Stream: 22440, Subtitle Stream: -1
Nov 06, 2021 20:43:00.554 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11434 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.554 [0x7fd7c2e78b38] DEBUG - Audio Stream: 22445, Subtitle Stream: -1
Nov 06, 2021 20:43:00.555 [0x7fd7c2e78b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 06, 2021 20:43:00.555 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11877 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.555 [0x7fd7c2e78b38] DEBUG - Audio Stream: 23174, Subtitle Stream: -1
Nov 06, 2021 20:43:00.555 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11879 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.555 [0x7fd7c2e78b38] DEBUG - Audio Stream: 23176, Subtitle Stream: -1
Nov 06, 2021 20:43:00.555 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11880 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.555 [0x7fd7c2e78b38] DEBUG - Audio Stream: 23177, Subtitle Stream: -1
Nov 06, 2021 20:43:00.556 [0x7fd7c2e78b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 06, 2021 20:43:00.556 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11883 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.556 [0x7fd7c2e78b38] DEBUG - Audio Stream: 23180, Subtitle Stream: -1
Nov 06, 2021 20:43:00.556 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11888 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.556 [0x7fd7c2e78b38] DEBUG - Audio Stream: 23185, Subtitle Stream: -1
Nov 06, 2021 20:43:00.557 [0x7fd7c2e78b38] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 06, 2021 20:43:00.557 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11714 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.557 [0x7fd7c2e78b38] DEBUG - Audio Stream: 22969, Subtitle Stream: -1
Nov 06, 2021 20:43:00.557 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11718 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.557 [0x7fd7c2e78b38] DEBUG - Audio Stream: 22973, Subtitle Stream: -1
Nov 06, 2021 20:43:00.557 [0x7fd7c2e78b38] DEBUG - Selecting best audio stream for part ID 11722 (autoselect: 1 language: en)
Nov 06, 2021 20:43:00.557 [0x7fd7c2e78b38] DEBUG - Audio Stream: 22977, Subtitle Stream: -1
Nov 06, 2021 20:43:00.560 [0x7fd7c4b05b38] DEBUG - Completed: [34.255.195.252:19101] 200 POST /playQueues?type=audio&playlistID=11806&shuffle=0&repeat=0 (4 live) TLS 61ms 40963 bytes
Nov 06, 2021 20:43:02.732 [0x7fd7c2e78b38] DEBUG - Request: [185.161.5.120:34503 (WAN)] GET /playlists/11806/composite/1634416550 (4 live) TLS GZIP Signed-in Token (garyandrew)
Nov 06, 2021 20:43:02.734 [0x7fd7c2e78b38] DEBUG - Content-Length of /config/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/f7/f7207015e0817802638a398c8f7105a44fdbd9be.jpg is 64915 (of total: 64915).
After this the logs so nothing - just the standard background chatter. No transcode or anything like you see when using one of the Echo devices that work (same account, same network)
So devs, any ideas? Is there another log I should be looking at? Had a poke in some of the other but nothing interesting that I could see (i.e. no errors)
Does plex staff read these forums?
doesn’t look like it.
I have finally found a work around for not playing sound on Alex - Plex
logon to plex on the web -
  1. www.plex.tv
  2. Settings
  3. Authorised Devices
  4. Click ‘X’ to Remove ‘Amazon Alexa’
  5. Ask Alexa to play your music
  6. Alex will confirm plex no longer linked
  7. Re-Link Plex through the Alexa app.
I’ve been trying for months to fix this and this finally works
Good luck
Hooray! It appears to be Amazon’s fix; not only Plex, but WJST Jet Set Radio and Kansas Public Radio (KPR) skills are working again as well.
The Amazon Tap still doesn’t yet play with any of those skills.
