No soundprint or wave pattern in seek bar
I’ve done a full analyze on the source lib of my plex server used in plex amp, and the soundprint visualizer shows only a circle with a line moving around it, and the seek bar doesn’t show the wave pattern as shown on the website.
Server says it’s up to date
Something else I should do?
It’s not the regular analysis; make sure you have this enabled:
Was set for a scheduled task only. Would I have to recreate the library or can I get it in at this point?
It should happen during the night, then, if your server is on.
No change since last night. I’ll rescan the library, rerun the
library analyze and keep an eye on the logs
The logs you’re looking for are the Plex Media Scanner Deep Analysis files.
Ok, I got some logs for this morning, showing
Jan 16, 2019 05:03:57.301 [0xb3a63b40] INFO - Plex Media Scanner v1.14.1.5488-cc260c476 - ubuntu PC i686 - build: linux-ubuntu-i686 - GMT 02:00
Jan 16, 2019 05:03:57.301 [0xb3a63b40] INFO - Linux version: 4.13.0-46-generic (#51-Ubuntu SMP Tue Jun 12 12:36:35 UTC 2018), language: en-ZA
Jan 16, 2019 05:03:57.301 [0xb3a63b40] INFO - Processor AMD Turion(tm) II Neo N40L Dual-Core Processor
Jan 16, 2019 05:03:57.302 [0xb3a63b40] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --analyze-loudness --force --item 124029 --log-file-suffix  Deep Analysis
There are about 5 of these logs showing similar and still no soundprint etc.
Can I kick start this, or would I have to recreate the library?
You definitely shouldn’t have to recreate the library.
Those lines look like perhaps just for single albums. Do you have loudness showing up anywhere?
Not that I have seen. I don’t know if I can find one easily. It’s a big haystack :smiley:
That log line shows 124029 which is probably the ID of an album. If you’re in the web app you should be able to browse an album and then change the ID in the URL to the one above.
Also, zipping up all your logs might be helpful as to be able to see why the Butler isn’t computing all this stuff overnight.
I’m seeing some tracks with soundprints now, so it is happening. I’ll see what I can do about the logs
