No subtitles please help
Hey,
I new to plex.
The last 2 weeks i had no problems with Subtitles, they where showing in every serie that i played.
Since 2 days i can’t see the subtitles any more.
In the agent everything is setup as it should be.
I even tried to solve the issue by installing sub zero.
Can anyone help.
Below you can find some screenshots.
You have disabled ‘Local Media Assets’.
You need it for external subtitles.
Re-enable it, but leave it at the bottom of the “agent stack”.
side note: don’t enable Opensubtitles and SubZero at the same time.
Also noteworthy:
thanks for the tip i will try it
