Plex does not identify external subtitles
Plex does not identify external subtitles, the subtitles are in the renamed folders according to PLEX site orientation, formatted in UTF8, the subtitles of the movie library are normal, however the TV SHOWS library does not appear. I do not know what to do. I’ve tried everything. On another server I do not have the plex pass enabled subtitles work normally.
Are you using Season 0x subfolders?
Did you enable the Local Media Assets agent?
Are the subtitle files named exactly like the video files (including upper/lower case)?
Have you checked access permissions for plex:plex?
The local media agent was disabled what is it? And the permissions I have never had are the same as those in the movies folder.
It scans and makes available all kinds of local assets, like subtitles, posters and other things. You need to have it activated, or you can’t use external subtitles.
I’m active, but if I go out and come back again he’ll uncheck it myself. It is not marked. After I dial is it necessary to make a rescan?
Try using a different web browser or use the hosted app instead of the local one app.plex.tv
Resolved, I do not believe it. Thank you very much, I was even in pain.
