"No upcoming airings" for scheduled TV Shows
Hey everyone,
since a few weeks I’m experiencing an issue with recording schedules shows.
As you can see there are upcoming airings shown in the EPG for the show “Auction Hunters”.
The recording settings are set with the following options:
  • Record: All episodes
  • Resolution: HD preferred (not “HD only”)
  • Channels: All
  • Recording Times: All
Anyhow the scheduled recording is listed as “no upcoming airings” in the recording list.
:warning: It doesn’t matter if channels or time is set to something specific, the issue stays the same.
:warning: When selecting Record: “This episode” instead of “All episodes” the scheduled recording is not showing in the list at all.
Anyone experiencing the same issue?
Server Version: 1.27.0.5897
Server OS: Synology DSM 7
I’m not having those issue, but I’m running on Linux. Any chance you have the episodes being aired in your Plex TV library already? By default Plex will skip episodes if you already have them.
If not, would you be able to provide debug level server logs covering the time period where you set up a series recording, and episodes you would expect to record are not showing as scheduled?
Thx for the hint :blush:
I checked this and found the episodes to be aired already recorded in my library in deed.
So this bug turned out to be a real cool feature :ok_hand:
