I don’t seem to have the (Upgrading Matching) in ellipsis menu icon in any of my libraries. I would like to use the newer Plex Movie Agent. Am I missing something?
Thanks for any assistance.
SupportArticles Upgrading an Old Movie Library to Use the Plex Movie Agent
It says (legacy). I know it’s been around for sometime now, but I just keep putting it off. I finally had a little time and started to look into how to update it.
It’s not available in the agents. I tried to follow the process outlined in the link I put in my post. That’s when I discovered that the upgrade feature was not available.
if you are using the current web app it was changed the “Library Upgrade Required” in the menu.
Regardless of how the old option was called all it did was the step that @dbirch mentioned then refreshed the metadata for library both of which you can do at any time manually
