No video output
Server Version#:1.23.2.4656
Web Player Version#:4.58.1
Android app Version#:8.18.1.25719 (1d75c2cc)
Roku Version#:6.7.24.7009-0d0d064dd
About a week, or so, ago I started having intermittent playback issues, IE. videos would just stop with an “unknown” error, but upon restarting the playback the video would playback just fine. About 4 days ago I lost all hardware transcoding and my server sits with 15 of my 16 threads at 100%, according to htop. This usage is even while no videos are being played. As of yesterday I have no video playback on my Roku , laptop, and phone.
Last night I reformatted all drives on my server and fresh installed Debian 10.9, and I am still having the same issue.
Pre fresh install logs
Logs4.zip (3.1 MB)
post fresh install
Logs5 fresh install.zip (2.6 MB)
Preferences, sensitive data redacted with hash tags
Preferences.zip (791 Bytes)
#neofetch
       _,met$$$$$gg.          root@plex
    ,g$$$$$$$$$$$$$$$P.       ---------
  ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 10 (buster) x86_64
 ,$$P'              `$$$.     Kernel: 4.19.0-16-amd64
',$$P       ,ggs.     `$$b:   Uptime: 15 hours, 20 mins
`d$$'     ,$P"'   .    $$$    Packages: 715 (dpkg)
 $$P      d$'     ,    $$P    Shell: bash 5.0.3
 $$:      $$.   -    ,d$$'    Terminal: /dev/pts/0
 $$;      Y$b._   _,d$P'      CPU: AMD Ryzen 7 2700X (16) @ 3.700GHz
 Y$$.    `.`"Y$$$$P"'         GPU: NVIDIA NVIDIA Corporation GP106GL
 `$$b      "-.__              GPU: ASPEED Technology, Inc. ASPEED Graphics Family
  `Y$$                        Memory: 690MiB / 32156MiB
   `Y$$.
     `$$b.
       `Y$$b.
          `"Y$b._
#id plex
uid=998(plex) gid=998(plex) groups=998(plex),44(video)
#ls -lh /dev/dri/
total 0
drwxr-xr-x 2 root root       100 Jun  7 01:42 by-path
crw-rw---- 1 root video 226,   0 Jun  7 01:42 card0
crw-rw---- 1 root video 226,   1 Jun  7 01:42 card1
crw-rw---- 1 root video 226, 128 Jun  7 01:42 renderD128
#nvidia-smi
Mon Jun  7 17:28:43 2021
| NVIDIA-SMI 418.181.07   Driver Version: 418.181.07   CUDA Version: 10.1     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  Quadro P2000        On   | 00000000:2B:00.0 Off |                  N/A |
| 47%   35C    P8     4W /  75W |      1MiB /  5059MiB |      0%      Default |
Any help will be greatly appreciated.
Kindly,
Eric
Did you update the Nvidia drivers?
There is a report somewhere about the latest (version: *85 ? ) that’s not being detected.
Folks are backing down to a slightly older nvidia driver version and having success again with the card being detected.
you can check /sys/module/nvidia and see if it’s realized to /dev/dri
Judging by the transcoder, it’s not seeing it at all and going straight to software.
Jun 07, 2021 01:11:10.754 [0x7f8c72122b38] DEBUG - [Transcode] Cleaning directory for session 54i371p91ijd6x80o6p2xoax ()
Jun 07, 2021 01:11:10.754 [0x7f8c72122b38] DEBUG - [Transcode] Starting a transcode session 54i371p91ijd6x80o6p2xoax at offset -1.0 (state=3)
Jun 07, 2021 01:11:10.822 [0x7f8c72122b38] DEBUG - [Transcode] [Universal] Using local file path instead of URL: /media/Movies/EM/2002/28_Days_Later/28_Days_Later_2002.mkv
Jun 07, 2021 01:11:10.897 [0x7f8c72122b38] DEBUG - [Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/fa235d6-3858-linux-x86_64/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'hevc' '-codec:1' 'ac3' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/media/Movies/EM/2002/28_Days_Later/28_Days_Later_2002.mkv' '-filter_complex' '[0:0]scale=w=720:h=404[0];[0]format=pix_fmts=yuv420p|nv12[1]' '-map' '[1]' '-codec:0' 'libx264' '-crf:0' '22' '-maxrate:0' '1290k' '-bufsize:0' '2580k' '-r:0' '23.975999999999999' '-preset:0' 'veryfast' '-x264opts:0' 'subme=2:me_range=4:rc_lookahead=20:me=hex' '-force_key_frames:0' 'expr:gte(t,n_forced*3)' '-filter_complex' '[0:1] aresample=async=1:ocl='\''stereo'\'':rematrix_maxval=60.000000dB:osr=48000[2]' '-map' '[2]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-b:1' '128k' '-f' 'dash' '-seg_duration' '3' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress'
Jun 07, 2021 01:11:10.897 [0x7f8c72122b38] DEBUG - [Transcode/JobRunner] Jobs: Starting child process with pid 8480
Jun 07, 2021 01:11:10.935 [0x7f8c7521cb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=startup (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.935 [0x7f8c74022b38] DEBUG - Completed: [127.0.0.1:58470] 204 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=startup (9 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Jun 07, 2021 01:11:10.942 [0x7f8c73a2ab38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=startup (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.942 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 204 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=startup (9 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Jun 07, 2021 01:11:10.942 [0x7f8c71aecb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=opening (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.942 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 204 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=opening (9 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Jun 07, 2021 01:11:10.944 [0x7f8c739f5b38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=opened (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.944 [0x7f8c74022b38] DEBUG - Completed: [127.0.0.1:58470] 204 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?status=opened (9 live) 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Jun 07, 2021 01:11:10.944 [0x7f8c7161cb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=0&id=0&codec=hevc&type=video (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.945 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=0&id=0&codec=hevc&type=video (9 live) 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Jun 07, 2021 01:11:10.945 [0x7f8c7169fb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=1&id=0&codec=ac3&type=audio (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.945 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=1&id=0&codec=ac3&type=audio (9 live) 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Jun 07, 2021 01:11:10.945 [0x7f8c73debb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=2&id=0&codec=ac3&type=audio (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.945 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=2&id=0&codec=ac3&type=audio (9 live) 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Jun 07, 2021 01:11:10.945 [0x7f8c71732b38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=3&id=0&codec=ac3&type=audio (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.945 [0x7f8c74022b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/stream?index=3&id=0&codec=ac3&type=audio (9 live) 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Jun 07, 2021 01:11:10.980 [0x7f8c7521cb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main&width=1920&height=1080&interlaced=0&sar=1:1&level=120&frameRate=23.976&disp_default=1 (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.980 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main&width=1920&height=1080&interlaced=0&sar=1:1&level=120&frameRate=23.976&disp_default=1 (9 live) 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
Jun 07, 2021 01:11:10.980 [0x7f8c73a2ab38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=1&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&disp_default=1 (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.980 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=1&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&disp_default=1 (9 live) 0ms 195 bytes (pipelined: 10) (range: bytes=0-)
Jun 07, 2021 01:11:10.980 [0x7f8c71aecb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=2&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000 (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.980 [0x7f8c74022b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=2&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000 (9 live) 0ms 195 bytes (pipelined: 11) (range: bytes=0-)
Jun 07, 2021 01:11:10.981 [0x7f8c739f5b38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=3&id=0&codec=ac3&type=audio&bitrate=224000&language=eng&channels=2&layout=stereo&sampleRate=48000 (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.981 [0x7f8c74022b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=3&id=0&codec=ac3&type=audio&bitrate=224000&language=eng&channels=2&layout=stereo&sampleRate=48000 (9 live) 0ms 195 bytes (pipelined: 12) (range: bytes=0-)
Jun 07, 2021 01:11:10.981 [0x7f8c7161cb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=4&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.981 [0x7f8c74045b38] DEBUG - Completed: [127.0.0.1:58470] 200 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress/streamDetail?index=4&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (9 live) 0ms 195 bytes (pipelined: 13) (range: bytes=0-)
Jun 07, 2021 01:11:10.982 [0x7f8c7169fb38] DEBUG - Request: [127.0.0.1:58470 (Loopback)] PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?duration=6787.621000 (9 live) Signed-in Token (erich_7719) (range: bytes=0-)
Jun 07, 2021 01:11:10.982 [0x7f8c72122b38] DEBUG - [Transcode] Started session successfully: 54i371p91ijd6x80o6p2xoax
Jun 07, 2021 01:11:10.983 [0x7f8c74022b38] DEBUG - Completed: [127.0.0.1:58470] 204 PUT /video/:/transcode/session/54i371p91ijd6x80o6p2xoax/0498300b-8e64-4c86-ac8d-ce03a3bdb141/progress?duration=6787.621000 (9 live) 0ms 203 bytes (pipelined: 14) (range: bytes=0-)
Jun 07, 2021 01:11:10.983 [0x7f8c74045b38] DEBUG - Completed: [192.168.1.11:35378] 200 GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F76242&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=700&location=lan&maxVideoBitrate=1500&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=0&mediaBufferSize=102400&session=54i371p91ijd6x80o6p2xoax&subtitles=burn&Accept-Language=en (9 live) TLS GZIP 244ms 1081 bytes (pipelined: 16)
Jun 07, 2021 01:11:11.007 [0x7f8c74022b38] DEBUG - Auth: authenticated user 1 as erich_7719
Jun 07, 2021 01:11:11.007 [0x7f8c73debb38] DEBUG - Request: [192.168.1.11:35378 (Subnet)] GET /status/sessions (9 live) TLS GZIP Signed-in Token (erich_7719)
Jun 07, 2021 01:11:11.007 [0x7f8c73debb38] DEBUG - [Now] Adding 0 sessions.
Jun 07, 2021 01:11:11.008 [0x7f8c74022b38] DEBUG - Completed: [192.168.1.11:35378] 200 GET /status/sessions (9 live) TLS GZIP 0ms 480 bytes (pipelined: 17)
Jun 07, 2021 01:11:11.120 [0x7f8c71732b38] DEBUG - Request: [192.168.1.11:35378 (Subnet)] GET /video/:/transcode/universal/session/54i371p91ijd6x80o6p2xoax/1/header (9 live) TLS GZIP Signed-in
Jun 07, 2021 01:11:11.120 [0x7f8c7521cb38] DEBUG - Request: [192.168.1.11:35380 (Subnet)] GET /video/:/transcode/universal/session/54i371p91ijd6x80o6p2xoax/1/484.m4s (9 live) TLS GZIP Signed-in
Jun 07, 2021 01:11:11.120 [0x7f8c7521cb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Asked for segment 484 from session.
Jun 07, 2021 01:11:11.121 [0x7f8c73a2ab38] DEBUG - Request: [192.168.1.11:35372 (Subnet)] GET /video/:/transcode/universal/session/54i371p91ijd6x80o6p2xoax/0/header (9 live) TLS GZIP Signed-in
Jun 07, 2021 01:11:11.122 [0x7f8c71aecb38] DEBUG - Request: [192.168.1.11:35374 (Subnet)] GET /video/:/transcode/universal/session/54i371p91ijd6x80o6p2xoax/0/484.m4s (9 live) TLS GZIP Signed-in
Jun 07, 2021 01:11:11.122 [0x7f8c71aecb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Asked for segment 484 from session.
Jun 07, 2021 01:11:11.301 [0x7f8c715f9b38] DEBUG - Augment: Found a provider match for '28 Days Later'.
Jun 07, 2021 01:11:11.301 [0x7f8c715f9b38] DEBUG - Augment: Completed movie augmentation in 0.8 sec.
Jun 07, 2021 01:11:11.301 [0x7f8c75331b38] DEBUG - Activity: Ended activity 309f0f3a-5589-4966-9928-fd4b55f8596b.
Jun 07, 2021 01:11:11.559 [0x7f8c73debb38] DEBUG - [Transcode] Transcoder segment range: 0 - 0 (0)
Jun 07, 2021 01:11:11.560 [0x7f8c72122b38] DEBUG - [Transcode] Transcoder: session 54i371p91ijd6x80o6p2xoax indicated fallback to software decoding
Jun 07, 2021 01:11:11.573 [0x7f8c73a2ab38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Exists("/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-54i371p91ijd6x80o6p2xoax-0498300b-8e64-4c86-ac8d-ce03a3bdb141/init-stream0.m4s") => 1
Jun 07, 2021 01:11:11.573 [0x7f8c73a2ab38] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-54i371p91ijd6x80o6p2xoax-0498300b-8e64-4c86-ac8d-ce03a3bdb141/init-stream0.m4s is 810 (of total: 810).
Jun 07, 2021 01:11:11.574 [0x7f8c74045b38] DEBUG - Completed: [192.168.1.11:35372] 200 GET /video/:/transcode/universal/session/54i371p91ijd6x80o6p2xoax/0/header (9 live) TLS GZIP 452ms 810 bytes (pipelined: 10)
Jun 07, 2021 01:11:11.646 [0x7f8c71732b38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Exists("/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-54i371p91ijd6x80o6p2xoax-0498300b-8e64-4c86-ac8d-ce03a3bdb141/init-stream1.m4s") => 1
Jun 07, 2021 01:11:11.646 [0x7f8c71732b38] DEBUG - Content-Length of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-54i371p91ijd6x80o6p2xoax-0498300b-8e64-4c86-ac8d-ce03a3bdb141/init-stream1.m4s is 741 (of total: 741).
Jun 07, 2021 01:11:11.647 [0x7f8c74045b38] DEBUG - Completed: [192.168.1.11:35378] 200 GET /video/:/transcode/universal/session/54i371p91ijd6x80o6p2xoax/1/header (9 live) TLS GZIP 527ms 741 bytes (pipelined: 18)
Jun 07, 2021 01:11:11.925 [0x7f8c7169fb38] DEBUG - [Transcode] Transcoder segment range: 0 - 1 (1)
Jun 07, 2021 01:11:12.021 [0x7f8c7521cb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] We're in a seek: asked for 484, min/max available was 0/1
Jun 07, 2021 01:11:12.021 [0x7f8c7521cb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Segment #484 WON.
Jun 07, 2021 01:11:12.021 [0x7f8c7521cb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Killing job.
Jun 07, 2021 01:11:12.021 [0x7f8c7521cb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Signalling job ID 8480 with 9
Jun 07, 2021 01:11:12.021 [0x7f8c7521cb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Job was already killed, not killing again.
Jun 07, 2021 01:11:12.021 [0x7f8c7521cb38] DEBUG - [Transcode/54i371p91ijd6x80o6p2xoax] Stopping transcode session 54i371p91ijd6x80o6p2xoax
Jun 07, 2021 01:11:12.029 [0x7f8c75a60b38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 8480 is -9 (signal: Killed)
Jun 07, 2021 01:11:12.043 [0x7f8c74045b38] DEBUG - Auth: authenticated user 1 as erich_7719
Jun 07, 2021 01:11:12.043 [0x7f8c7161cb38] DEBUG - Request: [192.168.1.11:35378 (Subnet)] GET /status/sessions (8 live) TLS GZIP Signed-in Token (erich_7719)
Jun 07, 2021 01:11:12.043 [0x7f8c7161cb38] DEBUG - [Now] Adding 0 sessions.
I will give an older driver a try and will update the results.
Thank you very much for your time. I went back to NVIDIA-Linux-x86_64-450.119.03 driver and all apears to be working again.
Thank you again
