Not able to SSH
I am not able to SSH into my rasplex setup for some reason.  I get a connection refused, I can SSH into my XBMC no problem.
I really need to get in so I can change the skin because it is terribly slow right now.  Heard retouch works really well.
Disable and reenable the ssh service from Rasplex and it should work (in my case this was needed only once after flashing the SD).
