RasPlex .37 - ssh access not working
I just installed .37 on two different Pi's, and somehow I don't get ssh to work. Activated during initial setup, deactivated/activated with/without shutdown/restart through the config screen, but all I get is "connection refused", no matter whether I use putty from Windows, ssh on my Mac or ssh on my ReadyNAS (where PMS resides).
Samba which can be configured on the same screen works fine. I'm using both Pi's over wifi which works fine as well.
Any comments/ideas ?
Thx,
Max
I'm having the same problem, but deactivating and reactivating SSH from the config screen did the trick.
Thx, after de/reactivating ssh several times it now works on both Pi's, even after rebooting them.
Thank you! Disabling SSH, enabling SSH and rebooting fixed it! :)
