Not available outside your network every time
Plex Server: Version 1.32.7.7571
Hi guys, I’m having this issue from some time now. My server is going down for remote connections from time to time and the only way to let it go up again is disable and re-enable the UPnP on my modem (FritzBox) and restart the remote access on Plex.
I also used to set up the port manually on my modem but I got the same result after some time (I think it happened also more frequently to be honest).
Anyone is having the same issue?
I’ve downloaded the logs which I’m gonna post if necessary.
I personally would recommend not relying on UPNP for this. If your Plex server has a static IP on the local network, and you have setup port forwarding for Plex it should work.
If you can post the logs if you have them, it should help.
I have seen others with similar issues but I am on the current version, but I haven’t had any issues here.
