Not available outside your network
Server Version#:1.22.0.4163
Player Version#:everything
Hi!!!
ok, so i have this problem for 2-3 weeks now no matter what i do i cant accsess my server outside my nettwork, (remote accsess)
it only works local, when everything is on the same wifi.
i have tried everythin from port forward, changin router and deleting server and all that has to do with plex. nothing sems to work i am at my wits end.
is anyone else havin same problem and found anything that solved it???
I am having the same issue and cannot connect remotely.
Did you all get a fix for this? I can only access my library when on my home network. If I’m on LTE or outside of my home on a different WiFi network I get that my connection is currently unavailable.
Same here - use to be able to remotely, now nothing. Couple of seconds of green before booting me back off to red. Very frustrating.
Yeah, this is bullshit. Just started happening recently and their is no solution to this yet that I have found. Been running remote plex for years but now this…
i have a netgear night hawk and since a firmware upgrade on the router that’s when this issue started for me so i think it is something netgear has done in my case
Yeah, it turn out that it was 2 routers blocking one another, så i turned one of them to bridge, my network company sendt me ruter and not moden, the wierd thing is that everything was working for about 2 months, and then i suddenly had to turn one of them to bridge
