@x6 said:
Hey My Friend!!!
Look this!!!
Woo hoo! Thats wonderful!
OK, so here’s the next problem: how to connect to it remotely.
If you’re outside your network, you’ll have to make sure you’re able to connect to your IPv6 address with your client.
I don’t think the Android client can use IPv6, so you may have to use your browser.
I don’t really know the limitations of the Brazilian internet, buy I would guess it should work.
Just remember that you won’t be able to use any application that you can’t point directly at your own IPv6 address.
If you use the Android app, then you can use IPv4, or your MyPlex account, but not IPv6.
It’s late, and I need sleep, but ill check back tomorrow.
Good luck!
