Not getting all my channels on the guide
My dvr download shows that I have 228 channels enabled but the guide is showing only 58. I am using HD home run prime as my turner. I am using a Comcast TV card. When I use HD prime on the same computer I get all the channels
It sounds like you’re having an issue with the majority of your channels not being available in your selected lineup.
If you follow this link, you can report the issue with your lineup and hopefully it will corrected sooner than later.
I checked my dvr setting and it had the wrong provider. I deleted the dvr and reinstalled it . Everything is working fine.
