I’ve set up my tuned and the live TV and program guide are working on the web interface. When I go into the iOS app I am not seeing any live tv or the program guide at all. How do I get it to come up in the iOS app?
this is what i found.
Plex Forums http://forums.plex.tv/
mlacy7116 started a new discussion: Getting new management features to show up in Plex iOS app
Greetings!
I just got the management features (program guide and recording schedule) to work in iOS. It took a little bit of a process to get it working so I thought other Plexers might appreciate the information.
Keep in mind that I already setup my antenna, HD Home Run box, and DVR on my server and this thread is not going to assist with that (initially).
This post is to get the iOS app to work with the new features of Live TV and DVR management in the iOS app.
1 )I first had to install Plex Server 1.7.2.X on the computer that I have server set up on.
Note: If you check for updates in server settings it will say it is up to date.
- I went to https://plex.tv/downloads/
and ran the Windows 7 install. (Make sure that you are signed into your Plex Pass account or the download won’t work.)
Note: I am running Windows 10, but I didn’t see a Windows 10 server download and the Windows 7 install has been running fine so far. I don’t see that it broke anything.
Another note: I just ran the install without uninstalling my current server.
- I uninstalled the iOS app and re-downloaded it from the app store, signed into it, and viola! new features working like a charm!
I hope this helps some other Plexers out there wanting to check out the new features!
I am an Uber Plex fan and tell all of my friends and co-workers about it!
Thanks Plex for consistently adding to your device compatibility and new features!
Reply to this email directly or follow the link below to check it out:
Note: Your signature will be included when replying directly by email unless you remove it first. Attachments will not be included when replying.
Check it out: http://forums.plex.tv/discussion/274122/getting-new-management-features-to-show-up-in-plex-ios-app
Thanks - that worked! Appreciate the quick response. I didn’t need to delete and reinstall the iOS app. Just manually update the servers.
No need to delete iOS app here either, thanks for the guide though.
