Nothing is recording
Server Version#: 1.20.0.3133
Player Version#: 4.34.4Plex Media Server Logs_2020-07-26_09-56-09.zip (7.2 MB)
Tuner Make/Model: Hauppauge Quad HD
Guide/Lineup name: Plex
Using XMLTV?:
Channel number/Name: All
Ever since the update nothing has been recording and when I go to rescan the channels all I get is a flashing clock that shows 12:00. I tried Wintv8.5 and channels come up and record just fine. Please resolve.
Server Version# 1.19.5.3112
Player Version# 4.34.3
Tuner: HDHomerun Quattro
Guide Name: PG Plex
Using Windows 10 Laptop
I don’t have an answer for you on the flashing time issue but I’m hoping you may be able to help me with my issue under this topic heading of “Nothing is Recording”.
I loaded live tv/dvr yesterday with no issues. Guide and What’s On tabs function normally. The issue is when I open any show, all I have is the “watch function button” but no “record button” (no red dot) so I cannot use the dvr function to record shows. This is also the case on my firestick 4K version when I open the live tv/dvr function. Any ideas?
I have shows in my dvr scheduler and then after the air date it disappears. If I look as it airs it says there is a problem with the tuner. I’m using Wintv and its recording fine so its an issue with Plex. Very fustrated right now because when I go to delete the DVR it wont find any channels.
Do you have WINTV loaded that can cause an issue with Plex, I have mine loaded because its not doing anything and I want to have shows recorded.
I do not have Wintv loaded. I have gone thru the setup a 2nd time after deleting the DVR and received the same results…no record button. All the other features and tabs work fine, the guide contains all the correct channels from my tuner but no record function…something I really wanted for the OTA content.
