Nvidia Shield - an error occurred... - Appears to be a bug with audio transcoding? (DTS MA)
Server Version#: 1.30.0.6486
Player Version#: 9.13.1.37459 (853091633)
This error occurs when I attempt to play a movie that contains DTS MA through an Nvidia Shield when my receiver is NOT powered on (i.e. the receiver is not decoding the audio track - it is off in passthrough mode). When I turn my receiver on, movie playback proceeds normally.
12-24 12:53:07.132  i: [Player][ExoPlayer] Track information has been changed.
12-24 12:53:07.132  i: [Player][ExoPlayer] Setting initial track selection...
12-24 12:53:07.132  i: [TrackSelectorHelper] Initialising (Video: 1, Audio: 1, Text: 0)
12-24 12:53:07.132  i: [TrackSelectorHelper] Type: 2 Auto
12-24 12:53:07.133  i: [TrackSelectorHelper] Type: 1 Auto
12-24 12:53:07.133  i: [TrackSelectorHelper] Type: 2 Auto
12-24 12:53:07.136  i: [TrackSelectorHelper] Type: 2 Auto
12-24 12:53:07.137  i: [TrackSelectorHelper] Type: 3 Disabled
12-24 12:53:07.137  i: [TrackSelectorHelper] Type: 1 Auto
12-24 12:53:07.137  i: [TrackSelectorHelper] Type: 2 Auto
12-24 12:53:07.138  i: [TrackSelectorHelper] Type: 3 Disabled
12-24 12:53:07.138  i: [TrackSelectorHelper] Type: 1 Auto
12-24 12:53:07.138  i: [TrackSelectorHelper] Type: 2 Auto
12-24 12:53:07.139  i: [TrackSelectorHelper] Type: 3 Disabled
12-24 12:53:07.139  i: [TrackSelectorHelper] Type: 1 Auto
12-24 12:53:07.139  i: [TrackSelectorHelper] Type: 2 Auto
12-24 12:53:07.151  i: [MediaCodecVideoSyncRenderer] Decoder initialised, after 0 attempts.
12-24 12:53:07.192  i: [ExoPlayer][EventLogger] videoDecoderInitialized [eventTime=6.57, mediaPos=1294.00, window=0, period=0, OMX.Nvidia.h265.decode]
12-24 12:53:07.193  i: [ExoPlayer][EventLogger] videoInputFormat [eventTime=6.57, mediaPos=1294.00, window=0, period=0, id=0, mimeType=video/hevc, bitrate=56091000, codecs=hevc, res=3840x2160, fps=23.976025]
12-24 12:53:07.194  i: [ExoPlayer][EventLogger] audioInputFormat [eventTime=6.57, mediaPos=1294.00, window=0, period=0, id=1, mimeType=audio/vnd.dts.hd, bitrate=0, codecs=dts, channels=8, sample_rate=48000, language=english, selectionFlags=[forced]]
12-24 12:53:07.195  i: [TranscodeSession] Updating session status
12-24 12:53:07.201  i: [TranscodeSession] Direct Play
12-24 12:53:08.200  i: [FFmpeg] [INFO] [CacheSource] Close requested, terminating.
12-24 12:53:08.200  i: [FFmpeg] [INFO] [FFmpegExtractor] Demuxer context has already been closed.
12-24 12:53:08.201  i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been closed successfully.
12-24 12:53:08.201  i: [FFmpeg] [INFO] [CacheSource] Closed successfully.
12-24 12:53:08.201  i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been terminated successfully.
12-24 12:53:08.458  i: [ExoPlayer][EventLogger] videoDisabled [eventTime=7.83, mediaPos=1294.00, window=0, period=0]
12-24 12:53:08.459  i: [ExoPlayer][EventLogger] audioDisabled [eventTime=7.83, mediaPos=1294.00, window=0, period=0]
12-24 12:53:08.463  i: [FFmpegExtractor] Interrupting extractor for release.
12-24 12:53:08.469  i: [FFmpegExtractor] Extractor has been released.
12-24 12:53:08.470  i: [FFmpeg] [INFO] [FFmpegExtractor] Closing demuxer context.
12-24 12:53:08.471  i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been closed successfully.
12-24 12:53:08.476  e: [ExoPlayer][EventLogger] playerFailed [eventTime=7.85, mediaPos=1294.00, window=0, period=0, errorCode=ERROR_CODE_AUDIO_TRACK_INIT_FAILED
  com.google.android.exoplayer2.r: MediaCodecAudioRenderer error, index=3, format=Format(1, null, null, audio/vnd.dts.hd, dts, 0, english, [-1, -1, -1.0], [8, 48000]), format_supported=YES
      at com.google.android.exoplayer2.x1.handleMessage(SourceFile:357)
      at android.os.Handler.dispatchMessage(Handler.java:102)
      at android.os.Looper.loop(Looper.java:223)
      at android.os.HandlerThread.run(HandlerThread.java:67)
  Caused by: com.google.android.exoplayer2.audio.u$b: AudioTrack init failed 0 Config(48000, 6396, 562498)
      at com.google.android.exoplayer2.audio.e0$f.b(SourceFile:56)
      at com.google.android.exoplayer2.audio.e0.F(SourceFile:7)
      at com.google.android.exoplayer2.audio.e0.G(SourceFile:9)
      at com.google.android.exoplayer2.audio.e0.S(SourceFile:6)
      at com.google.android.exoplayer2.audio.e0.f(SourceFile:116)
      at com.google.android.exoplayer2.audio.j0.Y(SourceFile:46)
      at y3.o.b(SourceFile:63)
      at y3.o.render(SourceFile:48)
      at com.google.android.exoplayer2.x1.p(SourceFile:91)
      at com.google.android.exoplayer2.x1.handleMessage(SourceFile:221)
      ... 3 more
      Suppressed: com.google.android.exoplayer2.audio.u$b: AudioTrack init failed 0 Config(48000, 6396, 562498)
          ... 13 more
      Caused by: java.lang.UnsupportedOperationException: Cannot create AudioTrack
          at android.media.AudioTrack$Builder.build(AudioTrack.java:1279)
          at com.google.android.exoplayer2.audio.e0$f.g(SourceFile:53)
          at com.google.android.exoplayer2.audio.e0$f.e(SourceFile:7)
          at com.google.android.exoplayer2.audio.e0$f.b(SourceFile:1)
          ... 12 more
      ... 12 more
12-24 12:53:08.476  e: [Player][ExoPlayer] Playback error detected
12-24 12:53:08.477  i: [Player][Timeline] Handling player error
12-24 12:53:08.477  i: [Player][Timeline] Playback stopped (error: true)
12-24 12:53:08.477  i: [Player][Timeline] Player error not known by server, reporting original player error (or a playback interrupted one)
12-24 12:53:08.478  i: [Player] Error reported: UnknownError (null)
12-24 12:53:08.478  e: An exception occurred: com.google.android.exoplayer2.r: MediaCodecAudioRenderer error, index=3, format=Format(1, null, null, audio/vnd.dts.hd, dts, 0, english, [-1, -1, -1.0], [8, 48000]), format_supported=YES
12-24 12:53:08.478  e: Stacktrace: com.google.android.exoplayer2.r: MediaCodecAudioRenderer error, index=3, format=Format(1, null, null, audio/vnd.dts.hd, dts, 0, english, [-1, -1, -1.0], [8, 48000]), format_supported=YES
	... 3 more
		... 13 more
		... 12 more
	... 12 more
12-24 12:53:08.481  i: [Player][Timeline] Playback stopped (error: false)
12-24 12:53:08.487  i: [TranscodeSession] Stopping...
12-24 12:53:08.488  i: [TranscodeSession] Session already stopped.
12-24 12:53:08.490  i: [Player][Error] Displaying player error...
12-24 12:53:08.490  i: [DialogBehaviour] Showing dialog.
12-24 12:53:08.492  i: [ExoPlayer][EventLogger] state [eventTime=7.87, mediaPos=1294.00, window=0, period=0, IDLE]
12-24 12:53:10.433  i: [Player] Engine being destroyed due to player deconstruction.
12-24 12:53:10.433  i: [EngineEventManager] onPlaybackStopped: Closed
12-24 12:53:10.433  i: [Player][Timeline] Playback stopped (error: false)
12-24 12:53:10.434  i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
12-24 12:53:10.434  i: [TranscodeSession] Stopping...
12-24 12:53:10.434  i: [TranscodeSession] Session already stopped.
12-24 12:53:10.435  i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: false
12-24 12:53:10.435  i: [SleepTimerBehaviour] Sleep timer behaviour changed.
12-24 12:53:10.435  i: [WiFiLockBehaviour] Releasing WiFi lock since playback was stopped.
12-24 12:53:10.435  i: [DisplayBehaviour] Cancelling stop playback runnable to prevent unexpected stop.
12-24 12:53:10.436  i: [MediaSessionBehaviour] Updating state to STOPPED
